Octopus Hose, Norma connector question
Old Mar 18, 2021 | 07:14 PM
michaelh's Avatar
They are hose clamp pliers. Amazon has them:
Amazon Amazon
For once, the US prices are higher than this side of the pond, so I'd shop around.
Your knuckles will thank you...
Old Mar 19, 2021 | 08:53 AM
JayJagJay's Avatar
Default Remove the TB and Plastic Intake
Except for the 2 10mm bolts under the throttle body (at this point I have only one under the throttle body because 1 is enough) this job is pretty quick and easy IF you are willing to remove the entire throttle body and plastic intake I one big lump and set it to the side. Makes life so so much easier.
I replaced my hoses last week.
There are 10 10mm bolts that hold the TB intake to the heads. With something electric they take 3min to remove. Then the LH vac tube where it plugs into lower TB, then 2 gas lines, then assorted plugs and such and the entire top end can be off in 15 - 20 min. Have some new seals for the intake to heads connection - good to replace those anyway.
Anyways, once the top end of the engine is removed everything is right there.
From there, there are 2 8mm (or 10mm) bolts that hold the metal connector tube braket which connects the hose from the front to the Norma and octopus... Once this is removed the Norma connection, and steel tube can be removed for easier working. All of the routing and such is much easier as well...
I destroyed the old Norma connection which is a PITA. Somehow I tricked myself into NOT using a barbed fitting and just running that front hose to the octopus directly. I feel dumb for doing it. The proximity of the plastic Norma to the RH CAT is too close for comfort and it (in my mind) is a matter of time.
I ziptied (like was mentioned) the Norma, raising it some, to the hard-ish AC line above it for a little added clearance...
Old Mar 19, 2021 | 08:58 AM
JayJagJay's Avatar
Before starting have a set O these.
Fuel line disconnect tool.
Can be had cheap.
Old Mar 19, 2021 | 01:33 PM
michaelh's Avatar
Typical. I didn't find this thread of Curtiss' when I was searching the other evening. (Well, it was in the X308 forum, m'lud)
https://www.jaguarforums.com/forum/x...94/#post906517
Some good pictures in there, particularly from post #15 on.
Old Mar 19, 2021 | 05:25 PM
JimmyL's Avatar
Talking
Nice video ^^^. Now I know all I ever wanted to know about norma connectors. I'm having the same problem with my federal income taxes. It's all so complicated. Must read the manual five times ! It takes twenty reads to figure out a simple problem - well maybe not so simple anymore. Should I just cut the thing off an clamp it, and have done with it ! Are they (norma connectors) really just a shortcut for production costs that will lead to leaks before their time ? Questions for the enlightened and the gurus.
Old Mar 20, 2021 | 06:55 AM
Jon89's Avatar
Yes indeed, these Norma connectors are lousy shortcuts for the build process on the factory floor. Your best bet is to cut them off and brass hose barb the connection at your earliest convenience....
Old Mar 20, 2021 | 10:47 AM
XK8 Rebel's Avatar
Agree completely! Mine was actually leaking out of the stupid NORMA connector past the o-ring. Had to destroy it to get it off as the coolant leak gummed everything up and it wouldn't budge. Did the replacement with the hose barb, heater hose section and stainless steel worm gear clamps. Hasn't leaked a drop since. Much more peace of mind.
Old Apr 6, 2021 | 11:26 AM
  #28
Ekskaar's Avatar
Originally Posted by Ekskaar
Wow, could really use that! Thanks a lot for the offer!
Octopus on mine is still in good shape, just a crack in non return valve (wonder how)
Originally Posted by michaelh
For the sake of the cost of the TB gasket, the job is much easier if you remove the TB.
@Ekskaar - I have the remains of my original octopus in the museum. I'd be happy to post the valve out to you if you wish, although if the octopus is old....
^^ PM me your address & I'll pop it in a jiffy bag.
Kodos to Michael for donating a heater system non return valve!
Great forum exist thanks to great people ,...with great knowledge (AND great variety of part on shelf )
Thanks Michael!
Old Apr 10, 2021 | 08:57 AM
Ekskaar's Avatar
Thanks Michael!
Today I dug up the octopus hose and replaced the cracked non return valve. The valve is deep down but with TB off the car and metal bracket with the many electrical connectors out of the way, it is better accessible than I expected.
Did not even drain the system😱.
lost less then 1 litre. (worked quickly, valve out-in)
Norma connections were okay, I did not touch them and leave them as is.
Will put all back together tomorrow.
Old Apr 10, 2021 | 01:34 PM
  #30
michaelh's Avatar
Ecchhh. Don't ya' just love plastic parts in cooling systems...
Old Apr 11, 2021 | 09:39 AM
  #31
Higgins's Avatar
Bit the bullet today and got the old octopus out, in pieces. Cut it off in several places and then pulled the pieces out. The work was done rather easily thanks to having the throttle body off since before. And having read all the advice in this eminent thread!
New octopus ready to go in
Old Apr 11, 2021 | 09:43 AM
  #32
Jon89's Avatar
Well done....
Old Apr 11, 2021 | 11:45 AM
  #33
Ekskaar's Avatar
Well done indeed;-).
I guess, like with all such undertakings...
Its a hell of a job, before you actually do it.
Still, it takes a lot of effort but if you summarise the time it takes, then an hour brings a lot of progress usually.
That is why I like to "wrench" on the old Jag as it is sooo satisfying😂.
Old Apr 11, 2021 | 12:24 PM
  #34
Higgins's Avatar
In my case I undertake LOTS of work in the engine bay area, hence many specific tasks get a lot easier thanks to lots of stuff already out of the way. Started with removal of the supercharger to change its pulley to a smaller one. That was one year ago.. one thing led to another.
With the supercharger off I decided to have all bearings and seals inside it replaced. That is done now, only refitting of the SC is pending
There will be a EGR delete. In the slot in the intake elbow where the EGR normally expells its yucky stuff I will instead inject water/meth. Piping is now routed from the trunk but the pump will be purchased later, probably next winter.
I replace almost almost every coolant/heating hose, but unfortunately some of them are still missing at Sng Barratt, waited two months for delivery now.
Both belts will be replaced, serpentine belt replaced yesterday
Probably forgot some stuff I replaced already. The car has been on jackstands for 16 months now
EDIT: Yes forgot some work that I have done during the time the car has been on jackstands:
-Thermostat replaced
-Nav unit delete. Working on a own solution based on a raspberry pi single board computer
-Cd changer delete
-Fitted a temperature sensor to the differential. Will be read from the raspberry pi
-lots of wiring work from the ECU and TCU connectors to read values into the raspberry pi
-Fitted usb port in the arm rest storage compartment
But it all started with a total refurbishment of the rear suspension and subframe, and fitment of a LSD. That project is almost finished now, only hubs and brakes left to fit. But thats another story..
Old Apr 11, 2021 | 02:35 PM
  #35
Ekskaar's Avatar
-Cd changer delete
I know, of topic but...Wow, great job👍.
I have 10% pulley upgrade as well.
Planning for homemade Water-methanol kit currently.
Will EGR delete not cause codes? It influences pre-calculated mixture map...
Like you, I overhauled the IRS😉. Put poly bushings in.
Did some stuff on these engines in the past...
Replaced head on current AJ-27s
Old Apr 11, 2021 | 02:56 PM
  #36
Higgins's Avatar
As I understand it, on a AJ27 up til year model 2000 you should be able to ditch the EGR without having issues with warning lights at the dash. Time will tell
Interesting you also plan for a DIY water/meth injection, I have been thinking in that direction too even if I havent yet decided which way to go. But ideally I would like to find a pump with a known flow/voltage input chart and do my own programming. But so far I have not found that pump
Maybe we can do a joint venture here?
Old Apr 11, 2021 | 03:12 PM
  #37
Ekskaar's Avatar
Hi Higgins,
I am a low budget-proofeveryonewrong kind a technician.
What I plan for will not get credits because it is not helping business who make a living of these systems.
So 200psi, injection solenoid, pressure switch kinda simple thing😂.
I will post. And read if you are first👍
Old Nov 4, 2022 | 08:35 AM
  #38
Joe Enge's Avatar
I know this post is old, but that tool helped a lot. I wanted to say thanks for the tip.
Ophitoxaemia
Oct 11, 2024 06:38 AM
David Dougherty
Mar 26, 2021 10:25 AM
Jon89
Feb 17, 2021 06:58 AM
vsol
May 10, 2017 01:05 PM
srpope80
Jan 26, 2012 04:02 PM
