Oil Burning Newby Question
Old Aug 21, 2013 | 02:32 PM
  #41
vonbunn's Avatar
Default that sounds very interesting
Originally Posted by OregonJag
My 97 uses about that much oil. It varies between 900 and 1300 miles per quart. I'm on the end of the scale that says if you can get through a tank of gas without adding oil then oil is cheaper than a rebuild. So, I've got a ways to go yet. I believe most of my oil is going by a few valve guides as it has the tell tale pinging that goes along with goosing it. No clouds of smoke killing the neighborhood mosquitoes and none on the ground. I do find oil in the intake under the TB that comes from the engine breather so some is getting pushed in from tired rings. On the other hand I just passed 181k driving to work yesterday, still on the original nikasil engine.
Especially since I heard all the hoopola about the N. Cylinder
vonbunn Dabb
Old Aug 21, 2013 | 02:35 PM
  #42
vonbunn's Avatar
Sorry about messing up your post, I'm new at this and everything it seems. I thought it was interesting since I have heard all the hoopla about the Ny. cylinder walls.
Thank you,
Dann (vonbunn)
Old Aug 21, 2013 | 02:42 PM
  #43
Gus's Avatar
Gus
Just a few things I put together about Nikasil engines
ZJag
26
Sep 5, 2016 03:33 PM
Scarecrow
Mar 28, 2016 03:17 AM
giandanielxk8
Sep 6, 2015 07:21 PM
Dymaxxion
Sep 4, 2015 02:40 PM
