Oil Change Question
Old Jun 11, 2008 | 07:02 AM
Trooperbsb's Avatar
Default Oil Change Question
Good morning.
I have yet to change in the oil in my newly acquired '97 XK8. The sticker indiciating the last oil change was taken off and I forgot to ask the previous owner. Therefore, to aire on the side of caution, I am going to change it this weekend. Is their anything in particular I need to know? I have owned American cars (mostly Fords) my entire life and have been accustomed to their simplicity. The Jag has opened up a new dimension that is a bit out of my comfort level, due mostly to being unfamiliar with the brand. At any rate, what do you recommend for oil, filter, etc? Thanks!
Old Jun 11, 2008 | 09:32 AM
ken@britishparts.com's Avatar
Default RE: Oil Change Question
Really, nothing out of the ordinary. We carry both the OE and aftermarket filters. I recommend you change the drain plug washer, but I'm **** that way. It takes more oil than an American car.
Don't forget jack stands! Be safe![sm=nono.gif]
Old Jun 11, 2008 | 09:55 AM
hlgeorge's Avatar
"drain plug washer"
There is a seperate washer? My dealer says the washer is part of the drain plug and requires a new plug.
Old Jun 11, 2008 | 10:09 PM
GordoCatCar's Avatar
It is an o-ring pressed into the mating surface of the plug. I have reused mine mulitple times. Just dont over torque. gordo
Old Jun 12, 2008 | 08:29 PM
jag_genius's Avatar
original old school plugs needed a washer type.. it seems to be updated with the newer ones.. with the oring built in to the drain plug.. you can buy just the oring.. when needed..
Forcedair1
Sep 8, 2025 01:57 PM
kelliott
May 31, 2022 05:26 PM
ZJag
26
Sep 5, 2016 03:33 PM
bdboyle
Sep 4, 2015 06:16 AM
pnwrs2000
Sep 3, 2015 11:55 AM
