Oil Cooler High Pressure Hose Split
Old May 7, 2012 | 01:51 AM
XKRacer's Avatar
I can't see why not, but why would you want to? Everything is already filtered
Old May 7, 2012 | 02:49 AM
plums's Avatar
Just mental meandering. Apparently, the bypass setups filter down to 2 microns versus the 10 microns of the full flow filters. The stock filtering is retained, but the bypass system continuously filters a diverted side stream of oil.
Have you ever tried the Porsche filters? They are the only other stock fitment with the same thread. But, they make some *huge* filters. Some look to be a foot long. Even the stock filters are a good size. Not like the tiny stock filters on later Jaguars.
Old May 7, 2012 | 04:12 AM
avos's Avatar
Maybe Porsche expects more wear? Or are they using a filter that can trap smaller particles?
The circuit in the front will only open when the oil reaches a certain high temperature, so it will not have a constant flow, but is under pressure all the time.
toronadomike
Jan 22, 2026 10:13 PM
dsnyder586
Dec 29, 2024 07:39 PM
KarimPA
Sep 12, 2015 08:15 AM
Dymaxxion
Sep 4, 2015 02:40 PM
OkieTim
Sep 2, 2015 12:48 PM
