Oil cooler radiator AN10?
Does anyone know of a radiator that fits the XKR that uses an AN10 fitting? I'm looking to convert the oil cooler system to standard parts so it's easier to fix and hopefully much more reliable. Swallows sell some AN10 fittings for the engine so I plan to use them and some stainless steel braided lines.
I have been looking at aftermarket oil coolers and they sem to have the same mounting system that the OEM coolers have so as long as the width is correct they should fit if I get the same height as well obviously.
I went with this one.
https://mattlewisracing.co.uk/produc...32&zCountry=UK
Mocal 10 row. 115mm
Got the rubber mounts too. Fitted no problem with braided lines. I posted about it somewhere.. cant find my old post...
Mocal 10 row. 115mm
Mocal 10 row. 115mm
Mocal 10 row. 115mm
Setrab series 6
Part No. 50-610-7612
This will be close
They make the seven row
I think this is the 10 row
Pretty sure it will bolt right on
Will be a little taller than the one on my 2005 XK8
Jack
This will be close
Jack
Regarding an oil cooler that uses AN-10 fittings, I recently eliminated the transmission cooler that was integrated into the radiator in favor of a stand-alone cooler for the transmission fluid. I installed it directly above the stock oil cooler.
it’s a 19 row AN-10 unit that’s deeper than the the stock XKR oil cooler. but they offer a 16 or 10 row that’s more close to the XKR’s oil cooler size. The 19 row barely fits. In retrospect, I would’ve used the 16 row as an inch less depth would’ve made the fitment much easier.
It’s a basic stacked plate cooler ( not the really cheap tube and fin type) that was fairly inexpensive (read: China). So far no leaks. And my transmission runs cooler and so does the engine coolant (barely).
the whole reason for this started when I had to replace the stock Jaguar radiator which leaked from the side plastic tank. The Nissen replacement radiator is NOT the same quality as the stock 20 year old XKR radiator and as result the engine ran about 10-15 degrees F hotter. I wasn’t surprised as others have posted the same results with the aftermarket radiator.. it does suck that there’s not another alternative of better quality, other than buying the Jaguar part.
But with the transmission fluid rerouted the engine coolant is marginally cooler. Nevertheless I’m very tempted to get a used stock radiator before next summers heat.
The same cooler type can be used for engine oil of course; here is the Amazon link:
https://a.co/d/hXI8sl1
Z
Z
Z
Z
I would compare the size of the stock cooler with what’s available. If you think a larger one would fit, then go larger. Just stay away from the “tube and fin” coolers. They are quite inefficient compared to the stacked plate coolers.
offhand I believe there’s unused space side to side but not that much space vertically. You might be able to fit a cooler that’s several inches longer with no problems.
be sure to get the PTFE lined hose. Anything else will degrade eventually.. this is hose I’m using and it’s doing very well so far; 8 months and counting on my daily driver XKR. Do a google search of PTFE hose and you’ll be a believer in it as the best material to carry fuel, oil, ATF, or any other automotive fluid.
of course I’d rather have an all metal line, but the routing makes that pretty hard for an amateur fix.
This was my first experience using the PTFE braided hose. I used up a couple of feet of it in the learning process. Pretty quickly I figured out what was the best technique for cutting and routing. And still ended up with 8 or more extra feet.
https://a.co/d/fA3pS52
Z
Z
Z
Z
On The Setrab web site it gives dimensions for all their coolers so you can be sure it will bolt right on.
I'll Check out the one Zray mentioned also. CHEAPER and hopefully as good or better.
I think the hose can be run from engine to cooler in one piece on each side. Fingers crossed.
Jack
I'm getting ready to install an oil cooler with -10 nylon braid ptfe hose sometime this winter as soon as I can get garage time. The cooler I mentioned has the same mounting dimensions as the original. My 2005 XK8 has a seven plate cooler but I will be using at least a 10 plate or larger if it will fit without getting in the way of something else. A 16 row would be great because it will do a better job of radiating head on a hot day while sitting traffic. The seven row is pretty punny when it comes to radiating heat is still air. Keep us posted with lots of pictures.
Jack
Jack
Yea I think that was me, I bought a set today. I just thought others might have found other alternatives.
Contact swallows and ask them how much for a complete kit with lines, cooler, fittings.
jACK
I am sure I'm going ot mess it up. Plan to use some string to trace the path roughly of the OEM lines so I can get the distance about right.
one word of caution. It is my understanding that nylon braid ptfe has a tighter bend radi than the stainless braid ptfe. I not sure but check it out before you order hose.
Jack
Before buying a non PTFE lined hose you might want to consider this:
the synthetic rubber compound in the hose you are considering is the same material that the stock hoses are made of. The track record of the stock hoses is abysmal.
If you are wanting the same quality as the OEM hose, then the rubber hose is the ticket. If you are wanting an upgrade to something better, then PTFE is the way to go.
A 150 C rated hose sounds nice. But I wouldn’t bet my engine on the long term durability and reliability on any rubber push-on type hose.
sure, the PTFE lined hoses are a pain in the *** to assemble. That’s because the tolerances are that close, and the non-elastic material will not swell up after a few heat cycles like the rubber hoses do.
Z
Z
