Oil Drain Plug Gasket
Old May 19, 2026 | 08:38 PM
Rex's Avatar
Rex
Default Oil Drain Plug Gasket
Read somewhere that you should replace the oil drain plug gasket at every oil change. Bought a supply for future use and read the package which states: “Change gasket every oil change”. “Do not use unless oil pan threads are stripped”. ??? I am confused.
Old May 19, 2026 | 09:01 PM
zray's Avatar
Likely China manufacturing:
they meant to say “Do not use IF threads are stripped”.
Old May 20, 2026 | 09:44 AM
motorcarman's Avatar
When I worked at the dealer, they provided a NEW rubber seal for the V8 cars at first, then started providing pan bolts with the seal incorporated.
I saved dozens of one-time-use pan bolts to use for myself.
After a few uses I discarded and replaced.
They will usually work for several oil changes if you do NOT over torque the bolt.(just my experience)
Old May 20, 2026 | 10:04 AM
Jon89's Avatar
During nearly 50 years of doing my own oil & filter changes, I do not recall ever having to replace an oil pan drain bolt. Not overtightening them is the key....
mhamilton
Jan 3, 2025 08:57 AM
Todd Wiens
Dec 24, 2022 04:40 PM
Gerard Radimaker
Jul 1, 2020 05:51 PM
DPK
Aug 19, 2015 09:46 AM
Rique
May 31, 2012 08:58 PM
