Oil Level
Old Dec 4, 2011 | 03:30 PM
walkman1's Avatar
Default Oil Level
I just had the oil changed as part of the winter storage prep. My mechanic put 8.5 quarts in and the level on the dipstick is about one half inch above the max mark. Could this cause some problems? The manual says capacity is 6.9 quarts without an oil cooler, and 7.7 with. I checked my previous oil change invoices and 8.5 quarts has been the norm.
Old Dec 4, 2011 | 04:12 PM
Gus's Avatar
Gus
It should not be a problem.
Old Dec 4, 2011 | 04:31 PM
randyb's Avatar
To much oil is a very big problem, it is worse than running low. Drain out some oil, easiest way is to take the filter off and drain the oil out if the filter and reinstall.
Old Dec 4, 2011 | 04:49 PM
Gus's Avatar
Gus
If you are 1 ½ qt over filled I would suggest that you have that corrected, if you are ½ qt I say leave it alone it will not harm a thing.
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
duecedriver
Dec 25, 2015 11:47 AM
mrplow58
Sep 15, 2015 09:58 PM
tonyforman
Sep 10, 2015 07:23 PM
