Oil pressure light but gauge always reds in the centre?
Old Mar 19, 2016 | 02:12 PM
Jagxk891's Avatar
Default Oil pressure light but gauge always reads in the centre?
Hi all I've noticed that the red light is always on near the oil pressure gauge but it reads in the middle and appears fine anyone have any idea how to extinguish this light
Old Mar 19, 2016 | 02:57 PM
mrplow58's Avatar
I would check the oil pressure, and if that is OK, I would replace the sensor for the light........Just what I would do......Mike
Old Mar 19, 2016 | 03:06 PM
RJ237's Avatar
The gauge is designed to read center scale as long as you have over about eight pounds, so follow Mike's advice since you don't know if you have a serious problem.
Old Mar 19, 2016 | 11:48 PM
scardini1's Avatar
Ditto. Never ignore a low oil pressure warning until you've checked the actual pressure. Same thing if the gauge is low, but the light is out. Make sure.
tom-r
Jan 11, 2017 03:22 PM
DougBoost
Mar 29, 2016 09:25 AM
pab
Mar 25, 2016 11:10 PM
cacamp
Mar 21, 2016 02:00 PM
rsq911
Mar 12, 2016 09:55 PM
