Oil on spark plugs?
Old Aug 24, 2010 | 06:45 PM
hm1's Avatar
hm1
Default Oil on spark plugs?
Well, finnaly know xhy the miss fires. I just installed new set of plugs, run the car... car starts missing......I check the plugs...covered in oil already. What should I do?? How serious is this??
Old Aug 24, 2010 | 07:52 PM
test point's Avatar
SERIOUS.
What year, miles?
Old Aug 24, 2010 | 09:11 PM
hm1's Avatar
hm1
1997 has 92k miles. It starts up fine, but has a miss..
Old Aug 24, 2010 | 09:13 PM
hm1's Avatar
hm1
Could it be the cam gaskets?
Old Aug 24, 2010 | 10:38 PM
Reverend Sam's Avatar
I was thinking piston rings. That would be a real chore to fix. Do you have blue smoke coming out of the tailpipe?
Old Aug 24, 2010 | 10:40 PM
hm1's Avatar
hm1
Nope. no smoke at all.. Just seams to have oil when I pulled the park plugs.
Old Aug 24, 2010 | 11:14 PM
MrTexasDan's Avatar
Hi HM1,
What does just seems to have oil when I pulled the plugs mean? Was there oil fouling the electrodes, which would indicate bad piston rings/cylinder bores (a bad thing)... or was the boot side of the plug covered in oil (above the threads) which indicates bad cam cover plug well seals (an easy fix).
Either one of these will cause misfiring.
Old Aug 24, 2010 | 11:31 PM
hm1's Avatar
hm1
It wasn't drenched in oil, just the plugs and the plug threads were a little wet(enough to cause a miss fire). There was some oil deep in that area, but not enough to cover the boots.
Old Aug 24, 2010 | 11:38 PM
MrTexasDan's Avatar
Ok, maybe it's me (it's been a long and brutal day and I'm not entirely here).
I'm still not clear on your description.
1) were the electrodes - the place that sparks - covered in oil?
- or -
2) was it the upper part of the spark plug body where the boot slips on and the metal part above the threads covered in oil?
Old Aug 24, 2010 | 11:40 PM
hm1's Avatar
hm1
I changed my plugs, because I have a miss fire. It ran great for two days, now it started again. It's not alot of oil, just enough to wet them. There is some oil in the cam cover area.
Old Aug 24, 2010 | 11:41 PM
hm1's Avatar
hm1
I will take pics tomorrow, thanks for the help
Old Aug 25, 2010 | 01:12 AM
viscoussquirrel's Avatar
92k could be piston rings, however I have found that valve guides generally wear out before the rings. First I'd run a compression test. Then do a leak down test. Hook up a compressor to the spark plug hole, put in a few psi. see if you can hear where the air coming out of. if you hear it leaking out the exhaust or the intake it's valves. If you hear it coming out of the dipstick tube, it's rings.
Old Aug 25, 2010 | 01:54 AM
hm1's Avatar
hm1
I went to do a coppreion check on it now, and dicided to start her up. She started right up, no problems. I even went for a drive, buttery smooth.. What could this be?
I had changed the oil few weeks ago with lightweight oil.. Could this be something to look into? Maybe some thicker oil for now, so it doesn't "seep" so much?
Old Aug 25, 2010 | 11:44 AM
What did the compression check show? These cars gave issues with cylinder bore washing from fuel which causes low compression which I suppose could cause some blow by. However this usually causes a no start issue so I dunno
Old Aug 25, 2010 | 11:50 AM
H20boy's Avatar
If you just switched to a different oil, synthetic, etc..valve cover gaskets and going back to a heavier weight oil should fix your problem. You're bound to keep getting oil in your plug wells until you do. The coil will eventually fail if you continue to let it misfire, and that's more expensive than just a plug.
cissdm
May 3, 2016 06:02 AM
caveforce
38
Nov 16, 2015 10:19 AM
Pristine97XK8Convertible
Sep 10, 2015 09:24 AM
mrplow58
Sep 9, 2015 11:27 AM
Bowman
Sep 3, 2015 03:17 PM
