Oil in Throttle body
My 01 XK8 has oil in the bottom of the Throttle body, anybody have and good ideas?
i cleaned the breather on the D/S valve cover w/3/32 drill bit and cleaned the TB and I still getting oil.
You didn't comment on the blockage found or not found.
You also didn't say how many miles on the car but oil is a sign of compression blow by past the rings if the part load breather tube is clear.
Try a can of 'RESTORE' and/or move up a weight in oil and see what that brings but a professional would do a compression test at this point.
Do you really have to buy a new valve cover or do they sell the plate and baffles separately?
The parts database does not show it as a separate part. If the cover was metal, I would say go for used, but a used plastic one might be risky.
In my case, I purchased a new valve cover from Gaudin for about $185. This will definitely help your problem.
xjrjag
Oct 24, 2024 03:09 PM
