oil usage on 97 xk8
Old Dec 4, 2017 | 05:14 PM
lorenzo45's Avatar
Default oil usage on 97 xk8
I seem to be using a quart of oil every 800 or so miles . Should I be worried that I might need an engine rebuild?
Old Dec 4, 2017 | 07:54 PM
CorStevens's Avatar
depends, what is the mileage, type of oil and driving conditions. perhaps you simply have a small leak. BTW this usage is normal in some vehicles. even if there is an issue, you might go 200k miles without it getting progressively worse.
Old Dec 5, 2017 | 03:26 AM
Welcome to the forum lorenzo45,
The Jaguar V8 doesn't tend to use oil. Is it leaking or burning it?
Old Dec 5, 2017 | 06:13 AM
Bones28's Avatar
I have a 97 XK8 100,000mls does not use any oil.
Old Dec 5, 2017 | 07:00 AM
TreVoRTasmin's Avatar
Mine goes through about the same. Maybe a quart every 1k (less if driven on the highway a lot). Chances are it is sucking it through the intake. Pull off your intake tube and have a look inside. I have thought about removing the breather tube and replacing both sides with a filter to see if that stops it but have been too lazy.
Tom Baker
Nov 11, 2018 06:57 PM
RJ237
Dec 3, 2017 12:55 PM
ALu
Nov 6, 2017 01:39 AM
dhardison
Nov 4, 2017 06:45 AM
klynn
Oct 20, 2017 03:49 PM
