Ok that wasn't pleasant!
Old Aug 8, 2014 | 12:13 PM
Stumpy's Avatar
Originally Posted by Stumpy
are any noises/clicks coming from the engine compartment, when you turn the key to the start position.
Reason I asked was there have been problems with the solenoid on the starter motor. Solenoid clicks but does not energise the motor itself. Can be intermittant.
See here: Technical Information - RepairkitsUK | Starter Motor Repair Kits | Don't Buy a New Start Motor - Repair It
Old Aug 8, 2014 | 05:10 PM
Loxmth's Avatar
The only clicking I heard was the second time it happened. It clicked for a few hours. I thought it would stop so the wife and I took her car to dinner. Came home and still clicking. Disconnected the negative reconnect in the morning and started right up and has not done it again.
I'm carrying an extra key just in case it's the chip. Other then that I'm thinking the shifter switch that tells the car it's not in drive or reverse.
Old Aug 19, 2014 | 06:44 PM
Loxmth's Avatar
Ok so she been good. Went out to eat finished and no start no turn over. Click click from the box behind the battery. I had left the driver door open while going to the trunk. Opened the trunk took out the clubs when the door open chime makes its noise. Car started right up. Got it home and parked it.
Went out to start her up and nothing. Turn the ignition to off and click click. Opened the trunk disconnected the negative and reattached after a minute. Started right up.
Oh BTW when it wouldn't start/ turnover there was a red light flashing near the shifter.
Old Aug 19, 2014 | 06:53 PM
DaveInVA's Avatar
Sounds like you might have a security module problem. The fact that moving things around in the area of the module which is in the trunk under the fuse box makes me think there may be a connection problem. Might be worth reseating the connections to that module.
Dave
Old Aug 19, 2014 | 07:02 PM
Loxmth's Avatar
Dave
Sounds like good advice . You talking about the ground?
Old Aug 19, 2014 | 07:10 PM
DaveInVA's Avatar
On one end of the module it has some plug in connectors. With the battery disconnected try unplugging them one at a time and replugging them in. The fact it flashed the light and made the chime when you moved things around might mean one of them isn't making good connection. Its the module underneath the fuse box in the trunk.
Dave
Old Aug 19, 2014 | 07:24 PM
Gus's Avatar
Gus
With the key in the car and your foot on the brake are you able to move the shifter? Are the dash lights on with the key on?
As for the security module in the red light flashing??
Old Aug 19, 2014 | 07:37 PM
  #28
Gus's Avatar
Gus
The red light flashing is indication that the security on the car was violated. Use your remote to cancel it and try another key. If that does not work you may need to look at the exciter ring at the ignition they have been known to fail preventing the car from restarting. The key has a chip in it that the security system via the exciter ring needs to see.
See if this link helps JagRepair.com - Jaguar Repair Information Resource
Old Sep 12, 2014 | 02:27 PM
Loxmth's Avatar
Default Update
She's been pretty good lately but last night was interesting. Opened the door and noticed the interior lights were dim. Wouldn't start. Before I would hear a clicking and the security light on the shift console was blinking. This time the dash/gauge lights were flickering. Very strange. Disconnected the negative and called it a night. Woke up this morning reconnected the negative and it started right up.
Took it to a garage and had the check the battery and the charging system. All is well and the battery is only a year old.
Any thoughts? Help. I never know when it's going to leave me stranded.
Old Sep 12, 2014 | 02:33 PM
  #30
DaveInVA's Avatar
Have you checked the connections on the fusible link box on the lower part of the panel behind the back seat in the trunk behind the spare tire?
Dave
Old Sep 12, 2014 | 02:59 PM
  #31
Loxmth's Avatar
Dave
No but I sure will. Thanks.
Old Sep 12, 2014 | 03:26 PM
  #32
Jon89's Avatar
Also check to see if the key flap in the ignition switch is properly closing when you remove your key. They have been known to stick and cause a battery drain. Wouldn't be a bad idea to lube your ignition switch innards with some graphite powder. Use it sparingly - just a quick spray will be more than enough. Then insert and remove your key a half-dozen times or so to distribute the graphite around inside the switch....
Old Sep 12, 2014 | 04:40 PM
  #33
Loxmth's Avatar
Wow,as a locksmith I wouldn't think of that. But when I just barely insert the key the wheel starts moving. Going to try that also.
Keeping them ideas coming guys I'll try the all.
Old Oct 1, 2017 | 01:53 PM
  #34
Loxmth's Avatar
I think I found the problem. It's been fine for months and all I did was not turn on the GPS/clock. ��
Believe it or not I've been living with this problem for years.
Old Oct 2, 2017 | 08:55 AM
  #35
JimmyL's Avatar
The GPS ?
Old Oct 2, 2017 | 07:51 PM
  #36
Loxmth's Avatar
Originally Posted by JimmyL
The GPS ?
Yes GPS. Why?
Finbarr1975
Sep 5, 2025 08:38 PM
hkmcmast
Nov 29, 2015 06:56 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
goingjag
Sep 30, 2015 09:27 PM
oldjaglover
Sep 29, 2015 03:27 PM
