Old Fuel Filter - hesitation under WOT
Old Sep 22, 2018 | 03:01 PM
Johnken's Avatar
Default Old Fuel Filter - hesitation under WOT
Yesterday I had some scary hesitation under wide open throttle. I thought about it and realized I hadn't changed my fuel filter in 30 or 40K miles. Well good news - it was almost solid, could hardly blow through it when I got it out. Car is running wonderfully again.
It's such an easy fix I figured I'd post this for future searches and as a friendly reminder - don't forget yours.
The clamp that holds the filter in place uses an 8mm bolt; The small nut on the fuel line came off with a 5/8 inch wrench (yes I know it should be metric on the Jag, but this worked perfectly). The 20amp (yellow) fuse for the fuel pump (pull it to depressurize the system) is #23 in the trunk's fuse box.
John
Old Sep 22, 2018 | 03:28 PM
John,
Good advice for US members where fuel quality seems to be an issue.
I change mine at the specified intervals but never find an issue with our UK fuel. I've even cut them open to check and the particulates are always minimal
Old Sep 23, 2018 | 07:14 AM
Jon89's Avatar
I replaced the factory fuel filter in my wife's 2006 XK8 as part of the 90,000-mile service. The few drops of fuel that leaked out of it after removal were a greyish color. I decided that an appropriate change interval going forward would be 60,000 miles. The vehicle now has 116,300 miles on it....
toronadomike
Jan 22, 2026 10:13 PM
May 7, 2023 04:58 AM
gtjoey
39
Aug 30, 2016 06:02 PM
thechief1967
Mar 11, 2016 07:46 AM
alvcars
Nov 21, 2013 07:44 PM
