Ominous low moan
Old Dec 22, 2009 | 03:57 PM
Jag69's Avatar
Default Ominous low moan
All,
2002 XK8 has been a happy camper of late, but I am getting a low moan/rumble under acceleration at between 60-70 mph. I stops above 70 or when I back off accelerator. Perhaps related is a clunk in the rear that has been there forever. When the power train engages (e.g. after coasting) the thunk occurs.
My mechanic (not a Jag guy, but competent) says the rear is fine. Thoughts?
Thanks in advance.
Old Dec 22, 2009 | 04:22 PM
Gus's Avatar
Gus
Universal joints! You have 2 on each axle that are often overlooked and not lubricated and will cause a rumbling noise. However, you could also have another problem and I would recommend that you have it checked by a transmission guy you trust if the u-joints are not the problem. The only reason I say this is that I had the same noise but mine was at 45-50mph. Check out my post https://www.jaguarforums.com/forum/s...ad.php?t=29038 Good Luck!
Old Dec 29, 2009 | 09:32 AM
Jag69's Avatar
Default Ominous Moan...
Are the universals a special order item or are they available off the shelf...
Thanks in advance
Old Dec 30, 2009 | 11:17 AM
Gus's Avatar
Gus
I had no trouble getting them that day.
X308XJR
May 20, 2019 06:50 PM
tampamark
Oct 11, 2015 10:03 PM
sedonajag
Oct 8, 2015 07:38 PM
RedRider48
Oct 1, 2015 08:18 AM
Bigvettefreak
Sep 28, 2015 03:03 AM
