Once again - upper shock mounts need replaced
Old Aug 20, 2020 | 03:12 PM
cjd777's Avatar
Not really, just taking the tension off enough to hold it in place. The exciting part is putting it back together.
I do use a sleeve at the top and run a bolt through the shock. Just undo the shock nut and release the spring a few inches and the worry is over.
If you use a coupe of hooks to hold the springs, I found that was a bit more worrisome. They tended to ****.
Old Aug 20, 2020 | 03:45 PM
Veteran: Navy
as Wayne said - just need to remove tension and I actually felt a lot safer doing this than with spring compressors from Advance or AutoZone. went this route to remove old and install new - worked quite well
wymjym
Mar 9, 2023 07:27 PM
Brettl
Jul 15, 2020 07:04 PM
David Dougherty
Nov 13, 2017 11:34 AM
jobagadonuts
Dec 6, 2016 04:42 PM
tlynch
Mar 15, 2016 11:35 PM
