One more supercharged XK8
Old Aug 10, 2015 | 01:54 AM
JagxkFan's Avatar
Sooo, the engine is in its new home. Filled it up with oil/water, did some cranking with the fuel pump fuse removed and voila-it fired right up. First time it was idling rough but it turned out to be an air leak at the duct seals which is now rectified. Now it's purring like a kitten. The only 2 codes are for the VVT, as the ECU is expecting to have the VVT, but the supercharged engine doesn't have VVT. But this doesn't cause the restricted performance or any trouble lights, so I don't care.
But still some bad news. The guy who had rebuilt my supercharger messed everything up and now it's impossible to even turn it by hand. It can be seen in the photo that the rotors are hitting each other. So I am very "pleased" to be looking forward to take everything apart again to remove my poor old Heaton... If the guy manages to fix it soon, I'll put it back as a temporarily solution just to drive during last warm months. If not, than I'll be waiting for the Twin Screw kit which is paid for and being produced right now by Avos. Let it be POWER!
Attached Thumbnails One more supercharged XK8-20150809_163437.jpg   One more supercharged XK8-20150809_145745.jpg   One more supercharged XK8-20150809_163449.jpg
Old Sep 7, 2015 | 07:14 AM
JagxkFan's Avatar
It's finished and runs great. Also added new Powerflex bushings, Adamesh springs and front upper spring mounts. Going make a Dyno run to find out how many new ponies are sitting under bonnet.
Old Oct 23, 2015 | 12:52 AM
JagxkFan's Avatar
Yesterday my local post suddenly brought me something special:
Old Dec 28, 2015 | 01:45 AM
JagxkFan's Avatar
Slowly moving on:
Cleaned/welded/powdercoated intercoolers and new 550cc injectors which will allow to reach high boost at high RPM safely without the need to increase the fuel pressure.
Attached Thumbnails One more supercharged XK8-20151128_192629.jpg   One more supercharged XK8-20151128_192644.jpg   One more supercharged XK8-20151226_194438.jpg
Old Dec 28, 2015 | 05:03 AM
Addicted2boost's Avatar
Very nice setup and write up! I still can't help thinking about the transmission being the weak link though. I hope everything goes your way.
Old Dec 28, 2015 | 07:09 AM
JagxkFan's Avatar
Thanks,
Yes, I also expect the tranny to be weak link, but so far it has been holding up well with Eaton. If it breaks after the Twin Screw installation, I'll rebuild it with stronger parts.
mrplow58
Jan 21, 2024 05:53 AM
Ozzy_UK
45
Feb 19, 2019 02:05 PM
JCam
Oct 23, 2016 08:27 PM
dieseldoc
Sep 28, 2015 01:17 PM
Get_Jaggy_With_It
Sep 25, 2015 03:09 PM
