OOPS and now I can't find it
So I was working on putting my amps in, and I was using the power wire going to the factory amp for power to my DSP. The dummy me forgot to pull power and had a spark from another power wire I was using on my amps. So I got everything hooked up but no power to my DSP. I checked the green and black wire, and no power. Well, my antenna does not go up, either. Well, that should be easy. So I checked the fuze in the luggage compartment for the antenna motor and power amp it was good. So I thought maybe the book was wrong, so I checked all the fuses, and they were all good. Can anyone help me out on what else it could be? The antenna and the amp power worked before because I used that same wire on another DSP installation. Everything else works.
Digital Signal Processor
@cdma - Both feeds to the PA and the one for the antenna motor are via fuse #9 (10A) in the trunk fusebox. BrownGreen wire colour.
Any issue with locking or reversing lamps?
vdpnyc
Sep 19, 2016 04:28 PM
