OOPS and now I can't find it
Old Sep 27, 2023 | 09:47 PM
cdma's Avatar
Default OOPS and now I can't find it
So I was working on putting my amps in, and I was using the power wire going to the factory amp for power to my DSP. The dummy me forgot to pull power and had a spark from another power wire I was using on my amps. So I got everything hooked up but no power to my DSP. I checked the green and black wire, and no power. Well, my antenna does not go up, either. Well, that should be easy. So I checked the fuze in the luggage compartment for the antenna motor and power amp it was good. So I thought maybe the book was wrong, so I checked all the fuses, and they were all good. Can anyone help me out on what else it could be? The antenna and the amp power worked before because I used that same wire on another DSP installation. Everything else works.
Old Sep 27, 2023 | 11:27 PM
baxtor's Avatar
Not sure l totally understand you, but the green black will only be triggering the antenna when appropriate. Not even sure if it goes live or ground from head unit.
Old Sep 28, 2023 | 12:50 AM
Pistnbroke's Avatar
WTF is a DSP
Old Sep 28, 2023 | 04:24 AM
michaelh's Avatar
Originally Posted by Pistnbroke
WTF is a DSP
Digital Signal Processor
@cdma - Both feeds to the PA and the one for the antenna motor are via fuse #9 (10A) in the trunk fusebox. BrownGreen wire colour.
Any issue with locking or reversing lamps?
1990XJ40
XJ40 ( XJ81 )
Nov 11, 2022 11:16 AM
robbing
Jun 29, 2017 12:41 PM
vdpnyc
Sep 19, 2016 04:28 PM
dsnyder586
Jul 17, 2016 08:23 PM
Loyer
E type ( XK-E )
Feb 24, 2013 12:54 AM
