Overheated XK8
Old Sep 20, 2016 | 05:10 PM
Eloianjag's Avatar
Default Overheated XK8
My 2001 XK8 had a pretty serious overheating episode leaving it with the restricted performance showing, I scanned it and came up with PO327 and PO332 which are the codes for the two knock sensors. the car starts right up and runs real smooth, no rattling or any unusual noises. Any ideas where I should start the repair process ? Can the overheating kill the sensors or ?...sure would appreciate any and all feedback
Old Sep 20, 2016 | 06:47 PM
motorcarman's Avatar
You probably MELTED the knock sensors on top of the block.
They are plastic coated sensors that don't like to be overheated.
I have a customer car (2002 XJR) in my 'boneyard' that was overheated and the sensors are just puddles of plastic goo. He does NOT want to repair it due to the cost involved.
Check the engine carefully when it is overheated.
bob
Old Sep 21, 2016 | 12:32 AM
Originally Posted by Eloianjag
My 2001 XK8 had a pretty serious overheating episode .........
I've moved your question from General Tech Help to XK8/XKR forum.
Old Sep 21, 2016 | 12:26 PM
Eloianjag's Avatar
[QUOTE=motorcarman;1538772]You probably MELTED the knock sensors on top of the block.
yeah...I removed the engine covers and there's a white powdery substance everywhere....is that from the meltdown ?.....what all should I check for ?,,, surely appreciate your input....
Old Sep 21, 2016 | 01:22 PM
You can see the knock sensors below the intake runners. They are in between the center 2 cylinders on each side. The wire harness connectors should be clipped to the thermostat tower.
The white powder might just be aluminum corrosion.
bob
JimC64
Sep 3, 2016 08:20 PM
mick99
Aug 30, 2016 03:38 PM
new2jag2016
Aug 27, 2016 01:02 AM
keelak
Aug 26, 2016 07:58 PM
Opie
Aug 23, 2016 04:37 PM
