oxygen sensor mix up?
Old Mar 1, 2013 | 12:58 PM
rrosscoe's Avatar
Default oxygen sensor mix up?
Hi guys and gals,
Here is a question for you all, is it possible to have the upstream o2 sensors connected to the the wrong plug? ie the A bank sensor actually connected to the B bank plug and vica versa, reason is i have a fault P1646 which is the A bank o2 sensor and also missfire on cylinder 8 on the B bank, if they were on the same bank that would sort of make sense but to be on opposite banks with no other faults is a bit confusing.
anyway will let you know what happens am having sensor changed, see if it clears both codes.
Old Mar 1, 2013 | 01:30 PM
I know it's possible to mix up the sensors on an XJ8L when replacing them - don't ask!
Old Mar 4, 2013 | 04:48 AM
rrosscoe's Avatar
Well,
sensor changed by local garage as had to use 4 post lift and 4ft breaker bar to remove it, the o2 code is now gone but still have miss fire on no 8 and occasionally on no 7 now, have changed plug and coil on 8 to no avail so will have to get the test meter to check the supply and ground's as per TIS, keep you in the loop,
regards
Old Mar 4, 2013 | 05:13 AM
steveinfrance's Avatar
Can you measure fuel trims?
Old Mar 4, 2013 | 10:03 AM
H20boy's Avatar
we have no idea what year your xk is, but if its a 4.0 (please put your info in your signature), remember those valve cover gaskets leak so very easily and could drip oil into the plug wells. Also, cyl 7 & 8 is right next to the oil filler neck. Another possible source of fluid into those plug wells.
Old Mar 5, 2013 | 07:49 AM
rrosscoe's Avatar
Sorry for lack of info,
2000 xkr 4.0 the engine had a complete rebuild (so I was told) prior to my purchase 2 year ago and has only done about 1000 or so miles and up to now has been fine (apart from an air leak at the throttle body inlet that was a sod to find) I have not checked the trims as I can only work on it at weekends and I have not got as far as that yet, There is no oil leaking into the plug recesses so that rules a short out, next step on saturday is to see if it is actually sparking at each cylinder at least I will know if it is the ECU or something else,
TO BE CONTINUED!
O by the way I have tried to input vehicle details into signature but havn't found out how to do it, as menioned it is proberbly an age thing
Old Mar 5, 2013 | 09:02 AM
User CP (top left)>edit signature (2/3 way down on L)
Old Mar 5, 2013 | 10:28 AM
rrosscoe's Avatar
MMMMM, tried it, it does have my vehicle details in the profile but not on any topic i join or start, bit like my car eh, IT DOESN'T LIKE ME
Poet
Feb 7, 2025 02:18 PM
carl purchase
Oct 14, 2015 06:14 PM
Dave1109971
Sep 30, 2015 11:04 PM
leep123
Sep 30, 2015 03:41 PM
Doug S
Sep 30, 2015 02:03 AM
