p0706 97 xk8
Old Aug 2, 2020 | 01:40 PM
stevez's Avatar
Default p0706 97 xk8
trans range switch new/ ecm repaired /abs repaired/ tcm cked npf as soon as you start code sets ohmed wires to tcm all wires to tcm good
Old Aug 2, 2020 | 01:49 PM
motorcarman's Avatar
The D4 switch in the selector illumination module is complaining about the circuit.
Check the round plastic plate moved by the selector lever and the little micro-switch at the front of the housing.
Old Aug 3, 2020 | 08:10 AM
stevez's Avatar
thanks will do
Old Aug 3, 2020 | 01:24 PM
stevez's Avatar
do u have diag info to ck that rotary switch
Old Aug 3, 2020 | 01:40 PM
Please do NOT use "textspeak" on the forums.
Old Aug 3, 2020 | 01:53 PM
Please find and read ALL TSBs related to the car you have. Jaguar went to the trouble of issuing bulletins to address many common problems.
P0706 is SPECIFICALLY addressed in TSB 307-05.
File Type: pdf
stevez
Aug 2, 2020 01:25 PM
BobRoy
Apr 12, 2016 05:56 PM
ali123
Aug 24, 2014 02:32 PM
dsnyder586
Mar 13, 2013 10:43 AM
Jack in CLT
Jun 18, 2010 12:29 PM
