P1000 P1637 Codes
Old Nov 6, 2009 | 09:32 AM
wheeble's Avatar
Default P1000 P1637 Codes
1999 XK8, Car fixed after ignition coil failure. No check eng light or restricted perf. car running great... But, I got P1000 and P1637 codes that will not clear. Is there a trick to resetting them? My Accutron OBDII reset the other associated codes after the coil failure, and I'm stumped how to clear these last codes.
Thanks in advance for any help.
Wheeble.
Old Nov 6, 2009 | 01:47 PM
test point's Avatar
The P1000 is a status record indicating that 'drive cycles' have not been completed since a 'clear'. Just ignore it and it will go away.
P1637 on the other hand decodes as follows:
CAN open circuit fault
ABS/TCCM to ECM circuit fault
ABS/TCCM failure
ECM failure
That's not going to clear until the problem is cleared. The chart says only that the cruise control is inhibited.
Old Nov 6, 2009 | 02:54 PM
wheeble's Avatar
The cruise work fine, no issues with the car at all. I think the code also sets if there were 2 successive sets of the same code. I'll drive the car as much as possibe this weekend and see what happens. Nothing straight forward with these Jags. I have had ABS faults a couple of times in the last 10 months or so, that might be what set the code.
Old Nov 6, 2009 | 03:02 PM
test point's Avatar
One last thought: I am sure you have been changing all the electronics out with the battery disconnected. But, why not try a cold boot to the entire system by disconnecting the battery and even shorting the disconnected chassis ground cable to the B+ to drain the entire system for a minute. If the code is still there you are not quite through yet.
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
JCam
Oct 23, 2016 08:27 PM
RollaJones
Sep 27, 2015 03:31 PM
