P1671 - Restricted Performance
Old Feb 1, 2011 | 01:24 PM
the dane's Avatar
Default P1671 - Restricted Performance
Hello all.
I've got a problem with code P1671; Fuel pump (2) relay. The car won't start unless you ground the ground the relay; the wiring is fine between the ECU and fuel pump relay. Are there any missing signals that can prevent the ECU from giving the ground signal to the relay? And, can I get a used ECM to 'plug and play'?
Old Feb 1, 2011 | 01:57 PM
WhiteXKR's Avatar
Question
What car? What year?
Old Feb 1, 2011 | 02:04 PM
the dane's Avatar
Sorry. 00' XKR
Old Feb 1, 2011 | 02:53 PM
H20boy's Avatar
ECMs for the earlier cars do tend to have some issues, and many owners have resorted to having theirs rebuilt...basically, repaired/reinforced solder connections internally. If you think its the ECM, I'd definitely look into that option. brgjag (member name) recently went thru a rebuild, so his thread should, IIRC have the company contact info in it.
Old Feb 1, 2011 | 03:38 PM
WhiteXKR's Avatar
Did you try to reset the interia fuel cutoff switch? I would think this would set a different code, but since it is easy to do, might be worth a try before you start swapping ECMs. It is in driver's side fuse box, between dash and door.
Old Feb 18, 2011 | 12:53 PM
the dane's Avatar
Sure did. I wish that was the problem.
Delta66
Oct 4, 2015 05:40 PM
Johncy2000
Oct 2, 2015 01:05 AM
1100me
Oct 1, 2015 11:49 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
