Painted Calipers
Old Nov 21, 2011 | 05:32 AM
Jochem00's Avatar
But black on black is nice too
Old Nov 27, 2011 | 08:56 PM
Rayd's Avatar
Is it necessary to prime the calipers before they are painted?
Old Nov 27, 2011 | 09:23 PM
Skid Mark's Avatar
I did not. No primer was in the kit. It's very thick, heat resistant paint, and the bare caliper has a rough finish to it, so perhaps it's blended to not need a primer.
Old Mar 2, 2012 | 03:45 PM
boughtsense's Avatar
Pomosv, those calipers are top notch! I have to get that done. Thanks for the pics and info.
Old Mar 3, 2012 | 05:39 PM
Skid Mark's Avatar
Originally Posted by pomosv
Nice job!
Govatos is right, that's a good tip on painting the back of the pads too (almost then makes it seem like a "full" brembo caliper), but the pads have to be removed for when you paint them otherwise the paint will hold the old pads in place and make a future replacement difficult.
Also, I'd give it a few coats of a high temp clearcoat, makes it last MUCH longer while preserving the shine and making sure the color doesn't fade. This is the 4th car I've painted calipers on and the clear coat makes all the difference for a long lasting finish years down the road.
Lastly, you can get "Jaguar" vinyl lettering, which you can then clearcoat over...nice touch that I personally think looks great, and the decals are cheap, just google for them if you're interested.
Overall I think for us non-brembo owners the Jag calipers look great painted, especially with that clean retainer spring in place too, a nice clean look without the cost of switching to a brembo system. A few pics of mine just to share..
Fronts:
Rears:
With the stock 18'' double fives on:
(would pop even more with bigger wheels, but I'm happy with my XKR as it is )
I know it's been a while, but I did take some inspiration from you, pomosv!
Old Mar 3, 2012 | 06:06 PM
bigjohnsonjeeps's Avatar
I did the caliper paint last week and it does make the whole car look nicer. I took everything apart and sprayed it. I had custom decals made and then I put a coat of hi-temp clear over everything.
Old Mar 5, 2012 | 09:54 AM
pomosv's Avatar
Looking good guys!
Old Mar 5, 2012 | 01:58 PM
  #28
Skid Mark's Avatar
Oops! Just noticed I put that decal on a little crooked. Good thing it's on the rear (less visibility)...
Old Mar 6, 2012 | 05:35 AM
XKRacer's Avatar
I posted a similar pic on the forum but thought I would get my 2c worth in
Old Mar 6, 2012 | 06:04 AM
  #30
Italianguy63's Avatar
BTW-- I have used high heat engine paint with good results... MC
Old Mar 6, 2012 | 06:51 AM
  #31
Skid Mark's Avatar
Wow, that''s a different configuration! What's the rationale?
Old Mar 6, 2012 | 07:03 AM
  #32
XKRacer's Avatar
Thats like an old XJ/XJS setup, actually even older Jaguar were using that config in XKE days, later on they changed it to outboard discs, even your XK is loosely based on it if you took it all out
Old Mar 6, 2012 | 07:04 AM
  #33
That's a mid 80's XJ-6 IRS. I put it in my 1936 Chevrolet project car. It is a custom "Scimitar GTE" style IRS conversion of my own design. Fabricated bottom plate, torque stays, tie bars, and trailing arms. Look in "my garage" for more info. (Not trying to hijack the thread!) MC
P.S. This is what happens when you take a Jag IRS out of "the cage."
Old Dec 27, 2012 | 11:04 PM
  #34
dirtyodwyer's Avatar
Nice job!
Fronts:
Rears:
Hey pomosv, didn't catch or see in the post what you used to paint your calipers. Did you use Dupli-color like some of the other guys on here? I'm looking to get my calipers painted since I'm doing a whole new rotors, brake pads, wheel painting/repairing thing. The shop that's gonna do the powder coating on my wheels said they can powder coat the calipers as well. I like the idea of painting the back of the pad the same color so I'd have to hand over the pads as well as the calipers to the shop. I guess they would then back on the color to the pad. Not sure if that's a good idea actually. Gonna look on line for the decal too. Seems like the XKRs have a different caliper than the standard XKs have, eh?
Attached Thumbnails Painted Calipers-4f18950b.jpg   Painted Calipers-2cc4b5be.jpg   Painted Calipers-c7f6736d.jpg
Old Dec 28, 2012 | 09:02 AM
  #35
user 2029223's Avatar
Banned
Buy the way boys, unless you are doing serious competition work, high temp. paint is unnecessary. I have used Rustoleum products with good results. Ditto on the clear coat Dirtyo.
Don't neglect the disk center hubs. Depending on your style of wheel a rusty center hub showing thru your wheel spokes is a mighty unattractive picture. I like gloss black in this application. Do not get paint on the hub to wheel mounting surfaces.
Old Dec 28, 2012 | 04:54 PM
  #36
Thanks tarheal - i was going to ask if rustoleum products would work just as well
Old Dec 28, 2012 | 08:17 PM
  #37
vettegood's Avatar
Default My 2001 XKR painted calipers
Here you go my 2001 XKR, I did the calipers and the drums.
I chose to do two colors, red for the calipers and gold for the drums.
My car color Roman Bronze has some gold fleck in it so I thought the color combo would go nicely.
Had the local sign shop do my vinyl lettering, just found some artwork on the internet and had them cut it out.
Notice the lettering on the rims as well.
The vinyl is gold color, too.
The job took 2 days , remove wheels , clean calipers using supplied brake cleaner and wire brush drill bit and a lot of elbow grease, paint, let dry between coats (2) and a day of curing the paint apply vinyl lettering and spray clear coat (quality automotive clear coat) over color and vinyl (4 coats).
The job has been done for about six months now and have not had any change in color or any chips.
After I completed the wheels it was so much fun ? and I enjoyed the results so much, I then tackled the engine!
Viola!
Happy New Year and
Happy Motoring...
Attached Thumbnails Painted Calipers-dscn2072.jpg   Painted Calipers-dscn2076.jpg   Painted Calipers-dscn2079.jpg   Painted Calipers-dscn2087.jpg   Painted Calipers-dscn2101.jpg
Painted Calipers-dscn2093.jpg   Painted Calipers-dscn2102.jpg   Painted Calipers-dscn2367.jpg
Old Dec 28, 2012 | 09:06 PM
  #38
pomosv's Avatar
I used the G2 caliper paint on mine. It's a thick epoxy paint that provides a nice heavy coat with a good gloss and doesn't chip, very durable. I topped it off with two coats of high temp clear coat (Duplicolor).
Since this thread I cleaned up and sprayed my hubs with a high temp silver paint, they look clean and get lost behind the wheels (now 20'' Detroits).
Nice job Vettegood, lots of attention to detail on your car. I'm personally not digging the gold on the hubs, but other than that everything looks tops notch, and your engine bay looks great (did you paint that yourself?).
Old Dec 29, 2012 | 02:45 PM
  #39
enderle's Avatar
Default I did mine color matched.
Figured I'd add to the thread. Here are mine color matched. Didn't do decals.
Old Dec 30, 2012 | 12:26 PM
  #40
fyi found the duplicolor in spray at Advance for under $8.00 - comes in red, black or silver
