Painted Calipers
Old Jan 3, 2013 | 05:41 PM
  #41
dirtyodwyer's Avatar
Just painted mycalipers red on my '07 XK. Looks great. Ready to apply the clear coat. How long do you guys suggest waiting to apply the coating? A couple of hours, a day? Gonna put the vinyl letters on first as well before clearcoating.
Old Jan 6, 2013 | 02:38 PM
  #42
I was starting to apply the Dupli-Color Engine Enamel clear coat on the calipers. The can says to apply within one hour of applying the color layer. Since I didn't do this in time, I decided to wait 5 days for the paint to cure. After 5 days I started to apply the clear coat with a brush and noticed the paint was coming off, so I stopped. Not sure if I can apply a clear coat at this point. Maybe I missed my window of opportunity while the paint was drying. Any suggestions?
I may just leave the calipers painted solely with the duplic color caliper paint. I did put 3 to 4 coats on each caliper so that may be enough.
And after that I applied the vinyl "Jaguar" lettering. Was hoping the clear coat would help seal these decals on the calipers.
Old Apr 15, 2013 | 02:22 AM
  #43
dannyS's Avatar
Hi Gents. I am attaching my recent caliper paint job done using Hi
Temp G2 caliper paint kit from Amazon Temp G2 caliper paint kit from Amazon
and Hi Temp Decal kit (silver) purchased on eBay for less then $10 (4 booklets of ten in multiple sizes - great quality btw). I don't have four jacks so I painted rear calipers first, let dry for an hour, applied the decals, and moved on to paint the front set. The worst part was putting the caliper clamp on afterwards without damaging the still pretty fresh paint . Anyway, below are the pics. Note the close match in color between the center cap and the caliper . Must like green to appreciate this
Attached Thumbnails Painted Calipers-caliperclose.jpg   Painted Calipers-caliperfar.jpg
Old Apr 15, 2013 | 02:32 AM
  #44
Neat job. I like the colour co-ordination.
Old Apr 15, 2013 | 10:02 AM
  #45
tberg's Avatar
Looks Great! Now if we could just figure out a way to keep them clean for more than an hour, that would be something.
Old Apr 15, 2013 | 01:07 PM
  #46
Jag#4's Avatar
Very nice. I like the matching green better than I would have thought. Looks good together.
Still working up the energy to do mine.
Old Apr 15, 2013 | 01:17 PM
  #47
WhiteXKR's Avatar
Likewise, I would not have thought to do green on a BRG car, but it looks great!
Old Apr 17, 2013 | 07:24 PM
  #48
dannyS's Avatar
Very pleased with the positive reception from such tough audience! There simply isn't a better reward than appreciation of one's work by others with similar passion . Planning on replacing rotors and pads this weekend with R1 drilled/slotted eLine series. Will post pictures after it's done hoping the hard fitting clamps wont rip of the caliper paint
Old Apr 18, 2013 | 09:53 AM
  #49
badkitty2000's Avatar
I've never used this particular paint, but there is a window of opportunity (usually 24 hours) to apply clear coat. Once the base coat cures, you need to "open it up" by sanding the surface before you apply clear. The easiest way to do this if you don't need to apply more color is with a ScotchBrite pad (grey) that you get at the auto parts store near the touch up paint. Just scuff, clean the surface and clear. Good luck!
Old Apr 26, 2013 | 02:38 AM
  #50
dannyS's Avatar
All four rotors and pads are swapped. It's quite a different experience braking on those rather budget R1 Eline rotors with PosiQuiet pads. It's nothing short of shockingly smooth...that being out of the way, I just noticed the match of the rotors not only with the center cap, but now also with the Jag emblem. Quite unintended coordination, but also pleasing at the same time .
Btw, the paint and the decals hold quite well! No chipping after popping of the caliper clips off or after putting new ones back on after the rotor upgrade.
Anyway, thanks all for inspiration!
bdboyle
Sep 16, 2019 05:58 PM
Larry-Cleveland
Feb 9, 2019 03:17 PM
wichita
E type ( XK-E )
Apr 16, 2016 04:00 AM
nlt624
Oct 2, 2015 03:36 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
