pan
Old May 29, 2017 | 10:22 AM
Zuscik's Avatar
Default pan
How can the ABS sensor be measured to confirm that it is good?
Old May 29, 2017 | 11:21 AM
avern1's Avatar
Below is a link to a thread that has extensive information for dealing with the ABS. My first thought is to have the codes read and then you will kow where the fault is located.
https://www.jaguarforums.com/forum/x...always-178795/
Old May 29, 2017 | 03:46 PM
RJ237's Avatar
Welcome to the forum Zuscik. If you have not done so please visit the new member area and introduce yourself. Link:
https://www.jaguarforums.com/forum/n...-intro-must-5/
Reading the codes in the Czech Republic may not be convenient, but searching for the cause of a ABS fault can be time consuming. It would help if you included the year and model in your post. Below is a link for testing the sensors and cables on most 4.0L V8's.
The resistance for the sensors is most often 1.0 to 1.4 ohms.
Often the problem is a poor solder connection to the ABS pump. Opening the case, cleaning the coating off the posts and resoldering will usually resolve the issue.
http://jagrepair.com/images/AutoRepa...heet%20XK8.pdf
Old May 30, 2017 | 02:43 AM
Welcome to the forum Zuscik,
You've posted this question in XK8/XKR forum but your profile shows you have an XF ......?
NZxkr
Aug 22, 2017 08:33 PM
saxandliz
Aug 14, 2017 06:28 PM
avisjaguar
May 2, 2017 03:07 PM
gkubrak
Mar 12, 2017 04:34 PM
danutcha
Mar 4, 2017 10:35 PM
