Park gear problem
Old Mar 13, 2019 | 01:10 PM
MDsjag's Avatar
Default Park gear problem
Can anyone tell me how to adjust the park gear? For some reason after putting transmission in it’s not working??
thanks for your help!!
Old Mar 13, 2019 | 05:39 PM
Johnken's Avatar
Can you please say more?
Did you just put a new transmission in ("after putting transmission in" - not sure if you mean new/repacement/rebuilt tranny or you meant to say put transmission park)?
What exactly happens (lever moves into park? Nothing engages? How do you get the key out?)
does the car run?
Is she shifting ok?
I think the more info you can give us the faster/better answer you'll get. Let us know.
John
Old Mar 13, 2019 | 06:11 PM
MDsjag's Avatar
Sorry about the lack of info. Yes it is a rebuilt transmission zf5hp24. It starts in park, shifts fine, park lights up but won’t lock to keep car from rolling. It’s just that transmission parking gear does not engage in park, so I have to use the emergency brake so car doesn’t roll. I have tried adjusting the shifting cable with no luck.
Old Mar 13, 2019 | 06:14 PM
MDsjag's Avatar
Sorry forgot to add...The key comes out fine while in park. You just have to make sure and use emergency brake.
Old Mar 13, 2019 | 09:02 PM
DavidYau's Avatar
Default Selector on ZF body
Have you checked the J Gate Gear lever module internals?
You said you tried adjusting the cable cable but was that at the side of the J gate?
You said the you had the ZF transmission body rebuilt. Have you checked the cable connector going to the ZF body’s selector. I think there’s an adjustment nut
snooktarpon
20
Feb 17, 2021 08:27 AM
coachdrew21
Apr 28, 2019 01:18 PM
03styper120k
22
Mar 19, 2017 03:08 PM
vdpnyc
Nov 6, 2016 08:08 AM
vsol
Mar 24, 2016 07:37 AM
