Park gear problem
Can you please say more?
Did you just put a new transmission in ("after putting transmission in" - not sure if you mean new/repacement/rebuilt tranny or you meant to say put transmission park)?
What exactly happens (lever moves into park? Nothing engages? How do you get the key out?)
does the car run?
Is she shifting ok?
I think the more info you can give us the faster/better answer you'll get. Let us know.
John
does the car run?
Is she shifting ok?
John
Sorry about the lack of info. Yes it is a rebuilt transmission zf5hp24. It starts in park, shifts fine, park lights up but won’t lock to keep car from rolling. It’s just that transmission parking gear does not engage in park, so I have to use the emergency brake so car doesn’t roll. I have tried adjusting the shifting cable with no luck.
Have you checked the J Gate Gear lever module internals?
You said you tried adjusting the cable cable but was that at the side of the J gate?
You said the you had the ZF transmission body rebuilt. Have you checked the cable connector going to the ZF body’s selector. I think there’s an adjustment nut
snooktarpon
20
Feb 17, 2021 08:27 AM
coachdrew21
Apr 28, 2019 01:18 PM
03styper120k
22
Mar 19, 2017 03:08 PM
vdpnyc
Nov 6, 2016 08:08 AM
vsol
Mar 24, 2016 07:37 AM
