Passenger Front Window Gremlins
Old Mar 27, 2023 | 04:07 PM
Chip Abbadessa's Avatar
Default Passenger Front Window Gremlins
Aloha Fellow XK8ers,
Having an issue with my passenger's side window. It worked intermittently and now , not so much. When I press either window switch (drivers, passengers) I only get a clicking sound both in the "up or down" direction. When locking the car, the door locks will cycle open/close about 5 times. Replaced the window module (used) but still the same issue. I just want to make sure if I replace the window motor I'm fixing the problem.
P.S. Anyone know if there is a non-OEM motor that will fit?
Many thanks in advance,
Old Mar 27, 2023 | 06:21 PM
Jon89's Avatar
Sounds like a door latch microswitch issue to me....
Old Mar 27, 2023 | 07:59 PM
motorcarman's Avatar
Try a HARD RESET and then door latch switch investigation as Jon89 suggested.
Old Mar 28, 2023 | 02:06 AM
Pistnbroke's Avatar
To check if its the motor put a bulb across the two wires feeding it ....if it lights but the motor does not run then its the motor...watch your fingers in there or you will loose them
ajmbwas
May 24, 2022 04:17 AM
Woodrun
Sep 18, 2018 10:51 AM
tibam13
Nov 4, 2014 04:10 AM
JCam
Sep 22, 2014 08:37 PM
mhamilton
Sep 23, 2013 09:19 PM
