passenger seat belt twisted on the drum
Old Oct 9, 2025 | 04:05 PM
stevepaa's Avatar
Default passenger seat belt twisted on the drum
My passenger seatbelt on 2001 xk8 has a twist behind the facia panel and it is twisted on the drum: hard to see but I can feel it. I cannot pull any belt out of the spool. How do I release the catch so I can pull more belt out and untwist it.
Old Oct 9, 2025 | 05:05 PM
stevepaa's Avatar
There are two connectors, how do I disconnect each.
Old Oct 9, 2025 | 06:20 PM
stevepaa's Avatar
I got the yellow one. I cannot figure out the other.
Old Oct 9, 2025 | 07:35 PM
stevepaa's Avatar
fixed without pulling the connector
I found a video showing how to orient the mechanism so that the ball inside releases.
It worked and I pulled the belt out and undid the twist
Old Oct 10, 2025 | 10:17 AM
zray's Avatar
post the video link so the next person with this issue can benefit.
Z
Old Oct 12, 2025 | 11:31 AM
Dr. D's Avatar
Yes, please post the fix. Curious minds want to know. Thanks
Old Oct 13, 2025 | 07:34 PM
stevepaa's Avatar
I have tried many times to find it, but could not.
On our belts there is a ball in a cage at the bottom of the mechanism. The ball only is free in the correct upright mounted position. Even slightly off and it will engage the locking mechanism. Mine got stuck and would not move. I removed the whole mechanism from its mounted position, tapped lightly with hand to get it free. Once free and in vertical position the belt easily came out several feet until the twist was uncovered. I then carefully let it rewind the belt, reinstalled and everything is fine.
uncle jim
Oct 10, 2016 09:23 AM
Autobahn kid
May 18, 2016 04:12 PM
Greg XK8
Mar 6, 2016 11:06 PM
Mark in Maine
Mar 18, 2015 03:57 PM
layres
Dec 28, 2012 04:00 PM
