Please clear up some idler pulley confusion.
Old Apr 9, 2016 | 04:23 PM
mcook's Avatar
Default Please clear up some idler pulley confusion.
I need to replace my idler pulley, which I believe the correct part number is AJ82266 1 (or C2C22758).
When I look at pictures in the various on-line parts retailers, they all look like the tensioner pulley, which has a rounded outer shoulder. The idler pulley in my case has a raised outer edge, presumably to stop the belt from flying off.
My question is; it it acceptable to use the round edge pulley or not?
Thanks.
Old Apr 9, 2016 | 04:54 PM
Addicted2boost's Avatar
You can use the rounded edge pulley. I have replaced lots of those plastic pulleys with raised edges because the bearings went bad in them. If I were you, I'd replace both the idler and tensioner pulley with that same P/N you listed above. The only thing is the bolt that holds the tensioner pulley to the tensioner itself is reverse threads. I wouldn't be concerned with a belt flying off, the harmonic balancer, A/C pulley, power steering pump pulley and water pump pulley have raised edges for belt alignment. There's more than enough ridges to make sure that doesn't happen.
Old Apr 10, 2016 | 11:53 AM
michaelh's Avatar
Just done this job today.
Used Dayco 89016 (no flange) for both tensioner and idler, $19 each from Amazon US.
Despite the low mileage, both were noisy: particularly the idler.
I believe the idler on the later models doesn't have the flange. Jaguar presumably decided that it wasn't necessary due to its proximity to the flanged alternator pulley.
M
oldish git
27
Jul 24, 2020 02:05 PM
JigJag
Jun 2, 2017 02:53 PM
Rubberlunchbox
May 19, 2016 08:25 AM
EZDriver
Apr 12, 2016 06:30 PM
Bhpbug
Apr 10, 2016 12:54 AM
