Pollen filter
Old 03-08-2013, 04:07 AM
azeteg's Avatar
Default Pollen filter
When buying service parts for my 100k service, I also bought a pollen filter, only to read, in several threads, that such a filter might not be fitted to my 2003 MY XKR Convertible.
Since I had felt my blower beeing weaker than I would expect, and having an annoying whine at level 3 and above, I decided to just dig in and see if there was a filter there or not. Lo and behold, there was. And it was far from pristine.
I first tried to remove the wipers without a puller - I can NOT recommend this. At first I tried without, but after half an hour of pulling, wiggling, prepping with corrosion eater and penetrating oils, I gave up and went to buy myself the puller. With the 2-jaw puller, they snapped off in a second.
With a sharp eye, you *may* be able to discern the new filter from the old.
Norri (03-08-2013)
Old 03-08-2013, 04:17 AM
ccfulton's Avatar
Received 1,106 Likes on 763 Posts
Yuck.
That's all I have to say about that.
Old 03-08-2013, 04:26 AM
GGG is offline
Received 16,822 Likes on 12,177 Posts
Did you have birds nesting in there?
Old 03-08-2013, 04:36 AM
azeteg's Avatar
No, but a cute little squirrel family. I carefully moved them to the air intake filter.
Old 03-08-2013, 05:50 AM
GGG is offline
Very considerate. They'll have the whole Inlet Trunk to play in now.
Old 03-08-2013, 07:56 AM
Jon89's Avatar
Received 4,294 Likes on 2,821 Posts
Very perplexing. Brutal has said several times here on the forum that pollen filters/cabin filters were not fitted into the XK series until the 2007 model year. Perhaps that is only true for the cars destined for the US. What's the story? Has anyone here in the US discovered that their 2006-and-older XK indeed has a pollen filter?
Old 03-08-2013, 10:31 AM
vettegood's Avatar
Yes, my 2001 XKR had a place for a pollen filter and one has been fitted without any alterations or adjustments.
I have not been able to ascertain if the correct blower adjustment has been done or even how to do it.
I believe you need a Jaguar software program to change the blower setting.
If anyone could chime in on this thought, it would be appreciated.
Happy Motoring...
kthrash
02-25-2019 10:20 AM
redxk8
10-04-2015 08:28 AM
reb1999
09-26-2015 08:41 AM
SD96XJ6L
09-25-2015 10:53 PM
Quick Reply: Pollen filter
