Poly Control Arm Bushings optoin
Old Feb 26, 2022 | 09:36 AM
David Dougherty's Avatar
Default Poly Control Arm Bushings optoin
I am getting ready to replace my front upper control arm bushing and I found this product. I am cautious about using poly bushings on suspension parts that need to give or insulate. As these seem perfect for keeping the geometry of the front suspension in place and all the swing arms need to do is rotate, I am in. The cost is compareable to aftermarket bushings and much less than "factory" ones. Plus they should last a lifetime and may also help keep the shock mount centered.
Old Feb 26, 2022 | 09:49 AM
Jon89's Avatar
When Wayne (cjd777) and I installed a pair of the Welsh upper front shock mounts along with new Bilstein shocks back in early January 2016 on my wife's 2006 XK8, we also installed a four-piece set of poly upper control arm bushings that I had ordered off eBay from a seller in the UK. I paid right at $75 for the set, and they arrived in about two weeks. They have held up quite well and after more than six years with them, I remain glad we made the decision to go with a poly set....
Old Feb 26, 2022 | 10:53 AM
you will be fine with these - I did the entire front/rear suspension with Powerflex bushings
Old Feb 26, 2022 | 11:04 AM
Johnken's Avatar
I use these too. All good.
John
Old Feb 26, 2022 | 12:18 PM
giandanielxk8's Avatar
I also use them and I love them. You do sacrifice a tiny bit of NVH, but not enough for it to be a concern to me.
sknight751
Jun 28, 2020 11:43 AM
NEO Cat
Jan 1, 2017 04:41 PM
kbeachy
Dec 12, 2014 09:40 PM
Gus
Nov 26, 2012 03:11 PM
Goldlion
Mar 15, 2011 11:44 AM
