POS
Old Aug 4, 2016 | 10:47 AM
Loxmth's Avatar
Default POS
It's the second Ford I've owned. I'll never own another. Electrical piece of junk. I've posted my problem here for over a year and I've done everything that was suggested. New battery, check all negative connections. Everything in the charging checks out fine. Think I'll let it rot into the ground where it belongs.
Old Aug 4, 2016 | 11:19 AM
brgjag's Avatar
huh, 03 models are known for being better then prior years.
Old Aug 4, 2016 | 11:53 AM
WhiteXKR's Avatar
Have you tried to squeeze the battery cable crimps in a vise or replaced the cables? Have you tightened the battery connections at the two megafuses in the rear of the the trunk? Have you tightened the battery connections at each fusebox?
These are all known problem areas for the symptoms you previously posted about.
Old Aug 4, 2016 | 01:37 PM
dsd's Avatar
dsd
Wait, a 13 year old car purchased at a fraction of its original price needs some sorting? That's weird.
Old Aug 4, 2016 | 02:07 PM
brgjag's Avatar
I have not read your other threads, what is the issue again, dare i ask?
Old Aug 4, 2016 | 06:54 PM
michaelh's Avatar
Retreat and regroup: put her aside for a while if you can.
These things can drive you to despair. Different car totally I know and somewhat off topic, but I spent two years on and off trying to track down an infuriating 'cut-out when hot and won't restart' on my MGB. Carbs, plugs, points, coil, condenser, yada yada... There were times when I could cheerfully have set it on fire
Finally tracked it down to the earthing braid in the distributor. I still don't know why but it's never reoccurred.
Anyways, my point is, there's always a solution. Don't let it beat you!
Mike
Old Aug 5, 2016 | 05:30 AM
jamdmyers's Avatar
I take it you'd done the last things with switching on/off locks Gus suggested in your recent post, you hadn't responded with results.
Good Battery, Fuses ok, grounds checked and ok, battery cables and terminals all checked and ok and tight. So that's your basic pwr supply.
You said there is clicking, where is it coming from? Is your foot on the brake?
The folks here will find it, They are all well knowledged.
A Hard reset will reset ECU/TCM to factory settings, not alot of other stuff (basically discharges ). Does anyone know if this affects the security module?
Old Aug 5, 2016 | 02:26 PM
Loxmth's Avatar
There are a couple of areas that WhiteXKR brought up that I haven't checked. I'll do that tomorrow.
I do love the car but had to vent.
Old Aug 5, 2016 | 02:46 PM
brgjag's Avatar
Take a few days off from the car. Come back to it later. Perhaps you missed something.
I had a Chevelle I bought back from inlaw. I drove it several times through the years, no issue.
I bought it back and twice before I left to drive it 350 miles home it would not start. I was like WTF. We replace plugs, wires, cap and rotor, then went back to it and it started, got it home. When at home it would not start again. Looked it over, no idea. Then I looked at the dizzy again and followed the hot wire from it to the fuse box in car. I am taller then my inlaw, he never HIT THE WIRE LOOSE in the fuse box with his foot. I am taller i was kicking it loose when I got in the car. I found that and fixed it, no more issue.
Sometimes it is right in front of us but we are so fed up we miss it.
That said, we are talking about a Jag. ha ha ha
Old Aug 5, 2016 | 02:50 PM
Loxmth's Avatar
Lol.Right!
My son seems to think it might be the alternator. It's the original but it checks out ok.
Old Aug 5, 2016 | 06:29 PM
brgjag's Avatar
How is it under a load?
Old Aug 30, 2016 | 04:15 PM
Loxmth's Avatar
Default Update
I think the problem has been fixed. The small junction box just I front of the spare tire had a loose nut. So far so good. It's has to be it. Thank God I was getting ready to drive it off a cliff.
Old Aug 31, 2016 | 12:54 AM
MediaBobNY's Avatar
'Reminded me of the E-Type's demise in the cult film 'Harold & Maude'.
Old Sep 1, 2016 | 06:48 AM
Loxmth's Avatar
Harold & Maude - The end of the E-Type - YouTube
Lol yup but without me in it.
prodigy215
Dec 17, 2022 10:18 AM
jagxkrtoofast
Dec 9, 2022 12:56 PM
qwertz2008
May 24, 2016 11:25 AM
xkrdave
May 11, 2016 02:23 PM
Ntimd8
May 8, 2016 06:40 PM
