Position of Front ABS Harness On U. Control Arm?
Old Aug 2, 2021 | 08:55 AM
kstevusa's Avatar
Default Position of Front ABS Harness On U. Control Arm?
Have notice pics of Front upper control arms with the harness located in slots attached with zip ties to the top of the arm and some attached underneath the arm with zip ties in the slots with wire underneath. Does anyone know the factory suggested method of installing these harnesses? Harness on top or underneath the U.C.A. ??
Old Aug 2, 2021 | 09:02 AM
cjd777's Avatar
Kelly, all I have messed with the wire was on top.
Old Aug 2, 2021 | 09:48 AM
Jon89's Avatar
The more slack you can provide, the better off you will be in terms of having to deal with ABS issues due to taut harnesses that eventually chafe or break....
Old Aug 3, 2021 | 05:23 AM
When I've done ones that hadn't previously been replaced (as they came from the factory), they were on top. I've always put them back the same way.
Old Aug 3, 2021 | 07:39 AM
David Dougherty's Avatar
Default Here you go
FrickenJag
Nov 23, 2017 11:58 AM
Razkid
Sep 2, 2017 04:34 PM
aleop
Jul 26, 2015 04:44 PM
oldmots
Oct 23, 2012 03:53 PM
