Possible Throttle Fault?
Old Dec 15, 2009 | 01:24 PM
Karl's Avatar
Default Possible Throttle Fault?
Hi guys and gals
My pride and joy seems to have developed a fault recently which is slowly but surely getting worse and I'm not quite sure of the cause.
Its a 1999 XKR 4.0. When at a steady speed (most noticeably at low speeds like 30mph) and on a constant throttle the engine will pick up speed and drop it randomly. Its feels like you are randomly applying more and then less pressure to the accelerator peddle, and can be quite violent. There is no lumpiness you might expect if a cylinder was not firing and it doesn’t seem to matter whether the engine is hot or cold.
Any ideas what might cause this? Its quite high mileage at 140k, if that helps.
Thanks everyone
Karl
Old Dec 15, 2009 | 02:25 PM
ken@britishparts.com's Avatar
Does it feel like it's struggling to find the proper gear?
Old Dec 15, 2009 | 02:52 PM
Gus's Avatar
Gus
Have you gone by Jaguar to see if your throttle body is up for replacement or reprogramming? This may help http://www.xclusively-jaguar.co.uk/xj04_fandi.html
Also do you have a check eng light with OBD codes? If so what are they?
Old Dec 15, 2009 | 02:58 PM
Brutal's Avatar
X'S 2 SOUNDS MORE LIKE THE TRANNY IS GEAR HUNTING
Old Dec 19, 2009 | 09:26 PM
Gus's Avatar
Gus
Well what did you find?
JaguarLover101
48
Jun 12, 2023 10:28 AM
zoozth
Sep 29, 2015 07:28 AM
Nigels420G
Mark V - X 420G
Sep 27, 2015 03:48 PM
thedugger1
Sep 26, 2015 10:27 PM
