Preferred tire pressure
Just looking for some feedback regarding members preferred tire pressure. My owner's manual gives a range of pressures to be used, depending on how fast the car is going to be driven.
What psi is working best for you ?
The opportunities for safely driving over 100 mph are becoming few and far between these days. So I'm hesitant to keep my tires inflated for high speed (+ 100 mph ) driving . I did manage to briefly venture into triple digit mph territory on my way home from Austin last Friday, but only for a few seconds. Those triple digit circumstances are likely to be rare, if ever again. So should I let some air out of the tires as the manual suggests, for enhanced comfort ? Will steering precision suffer ?
I always am more concerned with tire wear. 32/34 worked just fine on my '97, but the R and later xk8 with larger rears often experience center wear unless they drop to 32 or even 30 at the back.
My wife's 2006 XK8 does best at 32 to 33 psi in front and 28 to 29 psi in back (on 19-inch Atlas rims). These pressures allow for the longest treadwear and are also comfortable and safe for her. I spent the first twelve months of vehicle ownership adjusting the tire pressures before finally deciding on these settings....
Z7ray, she seems to be happiest at 32 34 for my xk8.
Just in case you never thought of this ( it took me 55 years to realize it) virtually nothing off the shelf in say an auto part store has respectable accuracy or precision. 5 to 10% error is common. I found a gauge on Amazon with 0.5% accuracy for around $30. Hope it helps.
BTW I agree with the spirit of your question. A pound or two makes a noticeable difference in handling and ride.
John
John
