Problem with xk8 radio/6 cd changer EXPERT advise needed
Old Jun 24, 2012 | 12:16 PM
RCSign's Avatar
I took mine apart two years ago, cleaned it reassembled and haven't had a problem since, Knock on wood.
Old Jun 25, 2012 | 09:18 AM
69duke's Avatar
Thanks for the advice. I took it apart and cleaned it with the air I use for the keyboard. Used electronic cleaner on the connections. Oiled it with 3 in one and it works fine now.
I was just wondering what the little buttons are for on the sides that say H and V. Is it some kind of leveling and if so how should I set them?
Old Jul 18, 2012 | 10:19 PM
DRV4SHOW's Avatar
With the help from this thread I was able to get my CD Changer to work again. Was giving me a NO DISC message. Takes patience but got it done. One little trick that was not mentioned was when replacing the rubber mounts I used a small socket 1/4" to press the mounts back into the pins. Hope this fix lasts.
Old Jul 19, 2012 | 07:06 AM
69duke's Avatar
Thanks. I took mine apart and cleaned and cleaned it and it now works fine. The only question I had was the V and H on the sides when it mounts. I know they would be for Horizontal and Vertical but I dont know how to set them.
Old Jul 19, 2012 | 11:05 AM
RCSign's Avatar
69Duke
I never noticed any setting on mine, Is there some kind of adjustment? If so I would guess that would be to make them as level as possible.
Old Jul 20, 2012 | 08:39 AM
DRV4SHOW's Avatar
I don't recall any markings on mine either. The mounting bolts did not provide for any adjustment.
Old Jul 23, 2012 | 10:41 AM
DRV4SHOW's Avatar
The fix was shortlived. Back to NO DISC message. There seems to be two similar changers for the XK8's. P/N LNC416OAA and LNF4160AA. Does anyone know if they are interchangeable or what mods are needed to interchange them? Thanks.
Old Aug 27, 2012 | 06:37 AM
  #28
plums's Avatar
Originally Posted by Jag#4
Decided to attempt the changer fix again. At one point yesterday, the FM side of the radio had stopped working. Today, with no assistance from me, it is again working just fine.
I got better access to the worm gears on the changer and worked them to what I think is the full stop position. But when I hooked it up to test, the head unit no longer recognizes CD mode. I have tried all the controls to switch it, but it is not recognizing CD mode in any fashion. The fuse index shows radio/tape only and the radio is OK. Is there another fuse for the CD player or have I fried something? I'm sure this will be humorous someday, just not today.
Maybe I don't really need a CD player.
The gears that you pictured are not the gears that usually cause trouble. Reference the PDF linked at: https://www.jaguarforums.com/forum/x...36/#post570475
The ones you want are in the corner of the unit.
Old Aug 27, 2012 | 09:18 AM
Jag#4's Avatar
Thanks Plums. It is still not working as I had moved on to more pressing issues. I will pull it back out and try again.
Old Aug 28, 2012 | 05:14 AM
  #30
mjlaris's Avatar
If you're intertested, I have both a radio and cd player from my 2002 XKR that I just removed a couple months ago; both were working fine. Let me know if you want one or both of them and you can have them for the price of shipping.
Mark
Old Aug 29, 2012 | 06:23 AM
  #31
jagmon's Avatar
I bought a I phone 4 with good ear plugs and internet , great sound and the world. I can call a tow truck for 45 dollars, AARP , discount.
Old Aug 29, 2012 | 08:59 AM
  #32
Jag#4's Avatar
Mark, a very generous offer. Assuming the CD will interchange with my 2001, I would definitely like to take you up on that. I will send you a PM for details.
Old Aug 29, 2012 | 10:04 AM
  #33
mjlaris's Avatar
My system is an Alpine like yours so it should be a direct swap. I PM'd you to make the arrangements.
Mark
Old Sep 20, 2012 | 07:58 PM
  #34
Lindasue's Avatar
Default Jaguar 2001 XK8 CD Changer/reads no disc and won't work
Hi. I can't get my cd changer to work. When I hit the cd button on the console, the changer in the trunk sounds like it's going through each cd in the magazine, but it's not fully loading any of them and ultimately stops with a reading of 'no disc.' I removed the cd changer from the brackets and have read a few posts on making it work again, but can't find directions on how they did it. Can someone walk me through it?
Old Sep 22, 2012 | 06:30 PM
  #35
Kadmiri's Avatar
it was the head unit I got it replaced with a flip out screen with navigation everything works great except 6 cd changer is useless
hafren
Aug 30, 2023 03:42 PM
Rupesh
Mar 25, 2016 03:33 PM
ControlIssues
Sep 3, 2015 07:38 PM
1964Daimler
Sep 2, 2015 11:41 PM
divingmom
Aug 25, 2015 07:54 PM
