Put Heat Shielding on Valley Hoses??
Old Oct 23, 2014 | 01:51 PM
brgjag's Avatar
Default Put Heat Shielding on Valley Hoses??
Would it help preserve the (new) valley hoses if I put heat shielding on them? Seems to me they would last longer if they had some plastic heat shielding on them, or some type of sheathing cover?????
Old Oct 23, 2014 | 08:46 PM
djpxk8's Avatar
Would be very interested in your replies, I am just about to change these hoses plus the octopus hoses!
Old Oct 23, 2014 | 09:06 PM
brgjag's Avatar
I would think I would have had many replies by now. Simple question, even in the title to get attn to the subject matter. I don't see the help here that I got back in 2010 or so when I had my first Jag.
Old Oct 23, 2014 | 09:13 PM
ccfulton's Avatar
Being that they are in an enclosed space with no real airflow around them, the hoses will eventually come to the local environmental temperature whether they are insulated or not.
I didn't bother when I replaced the hoses under the supercharger.
Old Oct 23, 2014 | 09:34 PM
Jandreu's Avatar
I can't help with your question but most folks don't log on everyday, give it a couple days and anyone with an opinion will chime in.
Never seen this question before so there may not be a lot of knowledge on the subject.
Old Oct 23, 2014 | 09:38 PM
Steve8's Avatar
+1 on this, there's no benefit to be had. And... they're containing coolant at the not-so-cool temperature of around 200F, they'll heat up pretty darn quickly.
Steve
Old Oct 24, 2014 | 03:37 AM
JagV8's Avatar
+1 nice idea but won't work, sadly.
Old Oct 24, 2014 | 03:48 AM
aode06's Avatar
It will not work, as the heat shielding will actually make the hose warmer and not cool down as fast.
What will work, is silicone hose, they outlast the vehicle.
Old Oct 24, 2014 | 08:36 AM
johns427's Avatar
Hoses on my mustang lasted 42 years.
Old Oct 24, 2014 | 05:57 PM
ShayneJ's Avatar
pardon my lack of knowledge on these hoses i have yet to have an issue with them
but has no one come up with a sturdier after market alternative like
metal or a higher grade of hose?
Old Oct 24, 2014 | 06:47 PM
brgjag's Avatar
Suspect it is not a daily driver???????
Old Nov 3, 2014 | 05:37 PM
Beav's Avatar
I was a professional mechanic 42 years ago and without exceptional, extenuating circumstances (read: massive luck, divine intervention, parts sourced from another galaxy) no automotive hose would be reliable at that age, at that time. It has only been the past 15-20 years that auto/hose makers realized the conductance of the cooling system was detrimental to hose life and made the corrections to allow near lifetime hoses.
Realize that in another ten years you'll probably need to remove the intake for some other reason and you can replace them then, provided you'll have the car that long. You could also replace them now with silicone hoses which can handle the heat better. Ask Tony how his are holding up.
Old Nov 21, 2015 | 08:52 PM
64vette's Avatar
While I agree that the Valley Hoses would not benefit from heat shielding, I will be adding shielding (similar to what's already on the fuel line in one location) to any hoses and plastic fittings that are above and near the catalytic converters and exhaust. Most of those fittings are rated for 125 deg C continuous, and I would be surprised if the "oven" above each converter does not exceed that.
dsnyder586
Dec 29, 2024 07:39 PM
PMKimpton
Aug 3, 2019 08:22 PM
martybmw
Sep 5, 2015 11:59 PM
