question about oil
Old Jul 8, 2018 | 04:32 PM
rontnm's Avatar
Default question about oil
Have a new old 2003 XK8 that needs a oil change and has 116,000 miles. was wondering if it is a ford engine and if it can take Valvoline high mileage synthetic oil.
Old Jul 8, 2018 | 05:20 PM
JagV8's Avatar
It's not a Ford engine. It's Jaguar's. Easiest is to use an oil meeting jag's spec.
Old Jul 8, 2018 | 05:35 PM
motorcarman's Avatar
Info for you. All this info is on this site SOMEWHERE and on the the internet. Gus has much info on his site and it is ORGANIZED so a search is less stressful.
bob
File Type: pdf
Old Jul 8, 2018 | 08:22 PM
Can the 2 posts be combined.
https://www.jaguarforums.com/forum/x...change-204573/
Old Jul 9, 2018 | 06:11 AM
CorStevens's Avatar
the high mileage oils seem to be best suited not when you cannot maintain specified oil pressures over the operating range but have excessive consumption. i have never seen these products help with oil consumption on a consistent basis outside of worn oil control rings.
are your pressures correct at all times and is your oil consumption reasonable? if both are yes, including a quart or so every 3000 US miles, continue to use normal specified oils.
better filters have a definite benefit and many manufacturers actually specify them to be replaced every other oil change, such as my 2008 Honda. purchase a good one with a glass core and there is no problem keeping it on every other change for a nice savings. abrasive grit from improper air filtering, air leaks and dirt in the oil from all causes is more of a problem than old or standard oil.
Addicted2boost
Feb 24, 2018 09:06 PM
Qvhk
Jan 1, 2018 10:10 AM
jagosaurus
Jan 10, 2013 12:55 PM
93xj6
Jul 27, 2007 08:57 AM
