Question on removing the roof console
Old Aug 6, 2016 | 02:27 AM
tassiejag's Avatar
Default Question on removing the roof console
Hi All, I am tackling the sagging headliner in my 2002 XKR coupe. I am removing the headliner myself and getting an upholstery shop to do the difficult bit with the re-covering. With the removal so far, I have got to the point of removing the roof console. I know it is held in place by 3 clips and I need to pop off the rear one first but I can't work out how to get the clip off the headliner. I don't want to damage the headliner base or the roof console so I am going carefully. Has anyone got a close up photo of the clip so I can see how to pop it off? Is it the same for the 2 clips towards the middle of the console? Does anyone have any tips on getting the console off without breaking anything? Any help is much appreciated.
As an aside, while I am doing the headliner I am also getting the A pillars and rear parcel shelf recovered, replacing the third brakelight and fixing the headrests but no problems with these matters.
Old Aug 6, 2016 | 04:10 AM
baxtor's Avatar
The rear clip is not exactly the same part as the two in front but it works exactly the same way. I have had mine off several times and l have found finger tips and a reasonable amount of force will get the job done. Make sure to pull away from roof squarely and evenly by working from back for a bit then sides and so on.
Old Aug 6, 2016 | 05:40 AM
..... and be careful with the metal spring clips - they have a bite like a rabid dog.
The 'teeth' on the sides face both inwards (to grip the console - arrowed blue) and outwards (to grip the locating hole - arrowed red).
Old Aug 6, 2016 | 05:32 PM
tassiejag's Avatar
Thanks Baxtor and Graham. I'll give it a go later today when my hands have warmed up! Only 4 degrees C here this morning.
Old Aug 6, 2016 | 05:43 PM
Ungn's Avatar
Here is a Picture of te clip locations in the Homelink Sticky Thread
Pull down gently and the clips should pop out of the slots.
Old Aug 7, 2016 | 03:42 AM
tassiejag's Avatar
Thank you all for your advice. I finally got my hands warmed up and pulled the console off. It was VERY tight. Ungn, the photo was very helpful in calming my nerves!
richzak
Jul 2, 2016 10:29 AM
o1xjr
Feb 17, 2016 06:10 AM
knowledge
Jun 27, 2012 12:47 AM
smokphattys
Dec 18, 2010 07:13 PM
jagxkrtoofast
Mar 8, 2010 08:17 PM
