Question for those who have a wind blocker
Old Nov 25, 2018 | 09:07 AM
dbtk44's Avatar
Question Question for those who have a wind blocker
I have a question for anyone who has a wind blocking device, doesn't matter what model of convertible, or the type and model of wind blocking device.
In regard to the piece that sits more or less parallel to the seats behind the headrests ( made of mesh, Poly carbonate, acrylic )....do you run yours angled back "/",
angled forward, or no angle at all "I" ?
And, if you made an angle adjustment, did you find that the different positions offered different performance..or, did it not really seem to matter much?
Thank you in advance! Any and all insight is sincerely appreciated
Old Nov 25, 2018 | 10:30 AM
max224's Avatar
I keep the wind blocker angled back when the top is up so it doesn't obscure my rear vision. With the top down, it is completely vertical and, from my personal experience, seems to function best that way. From what I understand, it blocks the rear turbulence which would otherwise be blowing around the front seat passengers. If you travel with a woman in the passenger seat, most of them are more concerned than we are about are hair blowing around, so it does pay (personal) dividends.
Old Nov 25, 2018 | 11:19 PM
dbtk44's Avatar
Thank you for the info max224, appreciate it! I can definitely see where it would be appreciated by the ladies.
Old Nov 26, 2018 | 04:52 AM
oyster's Avatar
Hi.
I keep mine angled slightly back. I think it looks better, and doesn't make any noticeable difference to the vertical position.
What really make a difference is the modification to the rear quarter windows control, so you can get the windows up with the top down.
Old Nov 26, 2018 | 06:04 PM
dbtk44's Avatar
Originally Posted by oyster
Hi.
Thank you oyster! I have read that the rear window mod makes a pretty dramatic difference
Old Nov 26, 2018 | 08:48 PM
StuG's Avatar
When I owned an MG convertible with a wind blocker (wind deflector) it seemed to work best in the vertical position.
Stu
Old Nov 29, 2018 | 03:42 AM
SailorSam's Avatar
We searched for a long time for the "correct" windbreak. One had been fitted from new but was missing when we bought the car. The Boss (She Who Must Be Obeyed) was not best pleased as her hair blew forward!
Once the windbreak was added all was well again, although best performance is with the windows closed.
The best performance is with the main part upright - the top part is angled back. Performance seems to deteriorate with increasing angle to the vertical. Played with it a lot when we first got it (new toy syndrome) but it is left set upright. The roof closes over it without problem.
Mark B
Old Nov 29, 2018 | 07:52 AM
dbtk44's Avatar
Stu
Thank you Stu!
Old Nov 29, 2018 | 08:02 AM
dbtk44's Avatar
Mark B
Thank you Mark!
I had to laugh a little when I read "She Who Must Be Obeyed"....because it's so true! My main motivation for seeking info about the wind blockers is, indeed, one of the female persuasion LoL
I believe you just inspired a new acronym...SWMBO
Old Nov 30, 2018 | 04:18 AM
frankc's Avatar
Mine is vertical. Never even thought about putting it at an angle. My vision through the deflector is unobscured. Just given me a thought. Its winter here but the sun is out.............. May just go for a top down drive.
Footnote.
For those thinking about getting a wind deflector note that there are two types. One set where you have to drill into the B pillar. The other type where you have to drill into the leather. Worth having though. I do not have any hair, well not much anyway, but I still find it more comfortable. It also stops you getting ear ache, from the woman sitting next to you.
Old Nov 30, 2018 | 10:24 AM
Barry_Tucker's Avatar
More or less vertical .......mine can be folded flat and I do this when the top is up. When I put the top down I just grab the deflector and pull it up until it hits the included stops....vertical "pretty much "
Old Dec 1, 2018 | 01:34 PM
Redline's Avatar
I've owned 4 small convertibles over the years and a behind-the-front-seat wind blocker/breaker/screen/deflector is not an option, it's a must-have. My bodacious GF and I have been comfortable in ambient temps down to freezing, (she likes the top down if it's not raining and she really makes the car look good when she's in it, which constitutes 2 votes to my 1...), whether cruising around town or motoring briskly across the nether regions of Nevada. Fully upright, the wind deflector is canted a few degrees forward by design, which helps to channel wind from the rear smoothly up and over our heads, (preventing turbulence), and it also keeps the interior quieter at speed. Because it will clear the roof when up, the raised deflector is also useful for "dimming" the headlights of trucks and cars behind us night or day, substantially reducing glare from the rearview mirror. And, I like the fact that the base section helps conceal anything left in the back seat.
Tilted backwards unacceptably reduces rear vision due to the density of the screen material, and, there's just no way to make the lines of the car look right. It's full up or full down as needed for us...
Old Dec 1, 2018 | 06:43 PM
bakntyme's Avatar
Thank you Mark!
Not related to the car...see the second paragraph of https://en.wikipedia.org/wiki/She:_A...y_of_Adventure regarding a novel from the 1880s. Before you ask, I am not quite old enough to have read it when originally published, but I have seen the 1965 movie not long after it was released.
Old Dec 2, 2018 | 11:21 AM
Terrific's Avatar
Had an acrylic one in a ZJS. Yes it blocked some wind. But if you check you'll find a lot of the wind still comes in between the seats and seat sides. These areas must be blocked also to be very effective.
Old Dec 4, 2018 | 11:21 AM
dbtk44's Avatar
Footnote.
Thank You Frankc! I've been weighing the pros and cons cons of the two different mounting systems...so far inconclusive..lol
Take her out and enjoy!
Old Dec 4, 2018 | 11:22 AM
dbtk44's Avatar
Thank you Barry!
Old Dec 4, 2018 | 11:34 AM
dbtk44's Avatar
Thank you Redline! So the heater is reasonably effective with the top down...good to know.
One of the reasons I'm looking into one is my frequent drives up to Henderson/Vegas, and that drive just begs for the top down.
Old Dec 4, 2018 | 11:41 AM
dbtk44's Avatar
Nice, thank you! I'll have to see if I can track down a copy, looks like an interesting read. 132 years in continuous print is VERY impressive...
So you're NOT 132? lol
Old Dec 4, 2018 | 11:44 AM
dbtk44's Avatar
Thank you terrific!
Seems like an ideal situation would be an acrylic/Lexan upright, and a horizontal platform that fills in a majority of the space to block most of the wind.
Old Dec 4, 2018 | 11:52 AM
I believe Rumpole of the Bailey was responsible for bringing it back into common use.
