Quick input/help TLC xk8
Old Feb 20, 2012 | 12:50 PM
ken qv's Avatar
Default Quick input/help TLC xk8
Ok guys.. looking for some quick help.. have some unexpected time off this week and want to knock out the big XK8 projects. Please help. Hoping to do the tensioners that really should be done... my understanding is that only the tops and guides have been failing? Who has the best prices on those parts. Also, since i would love to knock it out quick, what prices have guys been charged to have it done? I also need a few lifters and coils and valve cover gaskets. Hoping to not come across Lazy, i love due diligence and bookmark a lot of info, just wasn't expecting to have the next few days to jump into this and am calling around also... can't just review all the great info here in a day. thx
car is an 01 built 04/01 SAJD A42C6 1NA 21120
I think she just misses the cut off for upgraded tensioners
Old Feb 20, 2012 | 01:51 PM
test point's Avatar
Indeed she does miss the critical date for metal tensioners but do you know if they have not been changed?
Given the short time frame your local Ford or Lincoln dealer is the best bet for parts. Shipping from across the country would eat up most of the week for a few bucks. You will also need the cam timing tools. Some Ford/Lincoln dealers have been reported to rent them to customers since they are not used much. Then there is the zip tie method.
Secondary tensioners and bolts are about $130. If you feel the need or see evidence of gasket leaks they are available at your local auto parts store for the '00 - '02 Lincoln LS/Ford Thunderbird as FelPro part numbers for less than $40.
Here are a couple links:
Cam Chain Tensioners - Removing Valve Covers Only
https://www.jaguarforums.com/forum/j...17/#post316489
Cam Chain Tensioner Tools
https://www.jaguarforums.com/forum/g...20/#post471746
Help - sudden fail - Jaguar Forums - Jaguar Enthusiasts Forum
I just changed my own timing chain tensioners........ - Jaguar Forums - Jaguar Enthusiasts Forum
Ford tensioners for Jaguar??? - Jaguar Forums - Jaguar Enthusiasts Forum
Tensioners, when are they a "must replace" item? - Jaguar Forums - Jaguar Enthusiasts Forum
Free File Sharing Made Simple - MediaFire
DIY ~ Jaguar 4.0 (R&R) Timing belt, Tensioners, Water Pump, etc. - Calguns.net
Cam Chain Tensioners Lincoln LS Part Numbers
https://www.jaguarforums.com/forum/j...34/#post330655
Cam Chain Tensioners Cam Removal Method
2nd tensions DIY instruction FAQ - Jaguar Forums - Jaguar Enthusiasts Forum
You don't have 'lifters' and coil packs are easy for later after a web price search.
Shawn Svacha
Feb 6, 2022 04:53 PM
kiddhan625
Sep 25, 2015 12:04 PM
ssshield
Sep 24, 2015 08:29 PM
timfountain
Sep 17, 2015 05:12 PM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
