Quick one,- will these Hawk pads fit my XKR
To be honest, my experience with red stuff pads on my Caterham makes me reluctant to give them another try
But maybe I should if you vouch for them.
The part no. DP31140C is for the brembo rear right ?
I currently have them on my '02 XKR and couldn't be more satisfied. Have installed them on numerous performance vintage cars for myself and customers for nearly 20 years. From 911's to Shelby's, and everything in between, including vintage Sting Rays & GT-40's,
They do require a short break-in, and for best results, new rotors as well. Or at a minimum, the existing rotor should be resurfaced so they are 100% true. Considering how easy they are on the rotors, the bite is very good, and not an excessive level of dust.
Z.
If the picture is accurate, those pads are for the non-brembo brakes. Your original post seems correct.
QUOTE=clyons;1952268]If the picture is accurate, those pads are for the non-brembo brakes. Your original post seems correct.[/QUOTE]
Supersprint, I always buy my Hawk Pads from my friends at FrozenRotors.com I've used their Products for over 15 years....Started with my 2003 XKR with Drilled Brembo's and have continued with my 2005 XKR with the Red Drilled Package. They suggested I use Hawk's from the start and I have had great results with them.....Go there and check out several suggestions of Hawk Pads and if you have any questions about which ones you should use....Call or email them.....I think they are about the very best!
They have Hawks for both Drilled and Non-Drilled Rotors.....Race, Street, you name it!
Billy Clyde in Houston
When I needed good dust free pads in 2005 (had to ditch the bad performing Red Stuffs), there was not much choice for the brembo brake system, however the good thing was that our calipers/pads looked like the Ferrari F40s, and Hawk had these. Here are the correct Hawk part no's: Fronts HB193F.670 AND Rears HB194Z-570.
The best performing pads I used in terms of braking power where Pagid RS 4.2.1, but hard to remove black dust. Also the Ferrodo DS2500 seem to have very good braking power. EBC recommended the Yellow stuf to me after I mentioned my Red Stuff experience, and on paper I also think these will perform very well, but as they would dust more again I choose the Hawks.
The Hawk ceramics worked better for me of which I had about 4 sets. Since then more pads became available and as my power increased as well together with some sportier driving, I've switched to the race pads Pagid RS15, and now RST3 pads (warning they squeal, eat rotors, but awesome braking power from cold already)..
These pads look right, Brembo pads have two holes in them for the locating pins to run through. Check with Hawk to be sure, they will talk to you. The nice thing about the Brembos is the ease of changing pads.
Yes, that is the correct part number
HB194Z.570 = rear
HB193Z.670 = front
Both of these part numbers are Performance Ceramic compound
Thank you
Rachel Reiter
Hawk Customer Service Representative
Carlisle Brake & Friction
6180 Cochran Road
Solon, OH 44139
440-528-3209
rreiter@carlislecbf.com
jagxkrtoofast
Feb 16, 2012 07:39 AM
SteveM
Sep 4, 2010 12:27 PM
