Quick "Temporary" Fix
Old Jun 24, 2016 | 06:46 PM
Chuck Schexnayder's Avatar
Default Quick "Temporary" Fix
I'm sure there are those out there who have had this problem and the only way to correct it was to have it replaced by the local shop or dealer.
I'm talking about the thermostat housing splitting at the manufacturing's molding seam across the top as seen in the picture below--pointed out at the tip of the screwdriver.
I found myself in the situation while away from my shop and I didn't want to leave the car. So looking around for a solution I came upon one of those stainless steel screw clamps, just the right size. I opened it up so I could work it around the tube like housing then screwed it tight--thus forcing the seal closed. The housing was hot because I let the engine idle while doing this so I could see if it was going to work. As you can see in the 437 photo, it still leaked, but the leak you see is after a 50 mile drive.
If you have this problem, give this a try. It works. Just to be safe, I've since replaced the whole housing with new, but I'm keeping the clamp in the car.
Attached Thumbnails Quick "Temporary" Fix-img_0441.jpg   Quick "Temporary" Fix-img_0437.jpg
Old Jun 24, 2016 | 07:46 PM
Addicted2boost's Avatar
Good ingenuity. One thing I have done when replacing those plastic housings is to put some silicone sealer on the end caps. They all seem to leak there. I find it a little hard to believe that someone hasn't produced those in aluminum yet.
aholbro1
Feb 14, 2021 01:51 PM
Stoney85
Apr 14, 2016 03:05 AM
lcmjaguar
Apr 3, 2016 07:15 AM
Dean Kitching
Mar 30, 2016 02:53 PM
NathanDD6
Mar 30, 2016 05:32 AM
