Radiator fans not running
Old Aug 25, 2017 | 08:46 PM
Bob Ford's Avatar
Default Radiator fans not running
The car warms up. Hot to the touch, but the fans do not turn on as one would expect. However the dash says it's not hot. Is this normal?
____________
2000 XK8 (added by GGG)
Old Aug 26, 2017 | 12:48 AM
King Charles's Avatar
Bob welcome, & for the most accurate responses please include your car's details in your signature.
Do know the temp. gauges in these are notoriously inaccurate as they're so slow to register dangerous temps, it's usually too late once it does,so be aware.
Old Aug 26, 2017 | 08:06 AM
RJ237's Avatar
+1 to need car details.
If the gauge is in the red it's dangerously hot. Was that just when standing still or also while driving? It would be best to avoid using the car until the problem is resolved as you may be close to blowing a head gasket or dropping valve seats. You can download electrical system diagrams at jagrepair.com to help locate the fuses and modules.
Please visit the new member area and introduce yourself and you car:
https://www.jaguarforums.com/forum/n...-intro-must-5/
Old Aug 26, 2017 | 10:03 AM
JagV8's Avatar
Read ECT via OBD to see what the dash really is being told. If not as hot as a hot engine should be, investigate sensor/wiring/etc.
It won't put on the fan(s) unless told the engine is hot.
Old Aug 26, 2017 | 02:24 PM
Bob Ford's Avatar
At the time the car was not driven. Somehow the battery was drained and I jumped it off, let it run for 15 minutes and noticed the cooling fans not on. Also I get a coolant system low light.
Old Aug 26, 2017 | 05:09 PM
Originally Posted by Bob Ford
The car warms up. .....
Welcome to the forum Bob,
I've moved your question from X308 to X100 forum. This is the place to post questions about your model.
Old Aug 27, 2017 | 09:23 AM
Johnken's Avatar
Bob, the fan always comes on when a.c. is on. I dont think anyone had a chance to mention that. Thought you might be able to use that as a quick test.
John
Old Aug 27, 2017 | 12:09 PM
Bob Ford's Avatar
John
Thank you John! Nobody mentioned it.
Old Aug 28, 2017 | 02:20 PM
brgjag's Avatar
yea if you turn the air on they fans come on, both I think. If at a an idle from cold for just 15 running time they prob won't kick on.
If you have a low coolant light on, let it cool off and take the the cap off the expansion tank, fluid should be up to the bottom of the opening of the tank. If lower fill to that point, see if light goes away.
Old Aug 28, 2017 | 08:58 PM
oldmots's Avatar
There is a cooling fan module mounted on the shroud between the fans. If it has failed, the fans will not come on consistently. The module controls the fans from the ECU. Mine failed and the I found out when the ac got warm at stoplights.
