Radio code and LCD Screen
Old Aug 14, 2021 | 02:22 PM
PDMiller's Avatar
Default Radio code and LCD Screen
Hi All. I've been having battery problems with the XK and after jump starting it this morning I noticed that the LCD isn't working on the radio cassette head but the radio / CD player etc is working fine.
Foolishly I disconnected the battery in anticipation of the new one arriving so now I need to re-enter the code without a screen. I've done it loads of times with the screen but can't remember the exact sequence.
First question: Does it ask for the code as soon as I power it up and do I just press the four numbers one after the other?
Second question: Is it possible to replace the LCD and are they available?
Thanks in anticipation of any suggestions.
Old Aug 14, 2021 | 03:31 PM
michaelh's Avatar
From memory, that's all you need to do.
LCD theoretically could be replaced but not available anywhere, AFAIK.
Is it definitely dud (e.g. gone black) or just not illuminating?
Old Aug 14, 2021 | 04:08 PM
PDMiller's Avatar
Not sure, I'll check it out when the new battery arrives. If it's not illuminating might it be as simple as a duff bulb? Would I be so lucky?
Old Aug 15, 2021 | 01:32 AM
PDMiller's Avatar
Tried it this morning and it accepted the code . The screen is illuminating and it hasn't gone black, just no numbers on it?
Rafael
May 1, 2021 11:43 PM
Jenks63
Feb 2, 2021 09:58 AM
MtnJag
Sep 6, 2016 07:08 PM
Probesport
Feb 18, 2013 08:41 AM
Seth
Aug 13, 2012 09:19 AM
