Radio code worries
Old Jul 24, 2021 | 05:54 AM
Brtiii's Avatar
Default Radio code worries
I am considering a ecm reset and realized I don’t have a radio code. I tried all the dealers and even Jag corporate doesn’t have the code! They said they MIGHT BE ABLE TO GET IT if I had the radio serial #, can anybody help??? ‘’…. ‘99 Xk8 US delivery
btw tensioners we’re done previously and a new battery fitted also, I assume the battery was disconnected !
Old Jul 24, 2021 | 09:57 PM
Johnken's Avatar
Ultra rare for a USA car to have radio lockout as I've learned here.
Reread your question. Did you say battery recently replaced? If yes and no radio code needed there, this is closed, you don't need one mate.
Old Jul 25, 2021 | 11:11 AM
Originally Posted by Brtiii
..... a new battery fitted also, I assume the battery was disconnected !
Welcome to the forums Brtiii,
If the vehicle is fitted with a coded radio, the code is lost when the battery is disconnected. Although it is possible to maintain a supply (and 'learned' settings) with an external power source whilst changing a battery, this is unusual and the battery replacement without needing to enter a security code would suggest yours does NOT have a coded radio.
Old Jul 25, 2021 | 02:15 PM
Nickel's Avatar
I was worried about this also as I prepared to replace the timing chains, guides and tensioners on my 2001 XK8, but after a week and a half with battery disconnected, the radio did work without having to enter a code. Job done, no problems.
Old Jul 27, 2021 | 10:38 AM
TropicCat's Avatar
I made the mistake of buying a radio code from Radio-Code.com for a US spec car and then found out I didn't need it. $%^*!. For $35 you can get a code based on the car S/N if you REALLY need it. But wait until after you reconnect the battery before you make the same mistake I did.
TropicCat
Jul 13, 2021 10:51 AM
bdfdrmn
Oct 11, 2020 05:36 PM
agd
Apr 22, 2016 09:57 AM
jaguarlady03
May 17, 2013 03:09 PM
brat_4742003
Oct 16, 2010 10:14 PM
