Radio question
Old Jul 18, 2013 | 12:23 PM
Lakeland33813's Avatar
Question Radio question
I have a 2002 XK8 Convertible. When I turn my radio volume up past 20 the dash board speakers cut out and I only get the lower speakers to work. Almost like some sort of protection kicking in. My question is do I have a issue with the speakers or the amp portion of the factory stereo? The fix usually is to turn the volume down and turn the radio off for a few minutes. turning the volume down and turning the ignition off and back on also fixes the issue.
Old Jul 19, 2013 | 05:59 AM
Originally Posted by Lakeland33813
..... When I turn my radio volume up past 20 the dash board speakers cut out and I only get the lower speakers to work. .....
It appears from the 80 views so far and no replies that no one else plays the radio at this volume.
I didn't even know it went up to 35 but after testing can confirm that my premium sound system does NOT cut the dash speakers out after 5 minutes at maximum volume.
Old Jul 19, 2013 | 07:30 AM
WhiteXKR's Avatar
You might want to remove the speakers and check if they appear to be aftermarket replacements.
I do not know for sure if Jag used 2 or 4 ohm speakers, but if they were originally 4 ohm and were replaced with 2 ohm, that could potentially overload the amplifier and cause it to temporarily shut down as protection.
philwarner
Oct 4, 2024 01:37 PM
St.Regis
Oct 4, 2024 12:07 PM
Burdedw
Sep 12, 2015 10:39 AM
Greg Reed
Sep 9, 2015 07:20 PM
