Random Misfire - 1. hose question 2. i found a good cheap smoke machine
Hey all, i am hunting a Random Misfire issue P0300, I have replaced the fuel filter, the spark plugs and have rotated a new engine coil through each of the positions. Still happening. I purchased a cheap smoker (Autoline - it works so much better than my home made one) and I have found one leak so far.
1. Can someone tell me the name of the hose so I can buy a new one
I assume i need to take off the throttle body to replace this hose
I think that one has a o-ring that you can replace if it's on the right hand side. If it is that one there is some trick to releasing it, but I don't remember the procedure.
I think you nailed it, i went out and just touched it and it fell apart. So now I just need to find the part number.
^^^^^ This is the answer. From the pic, the pipe looks OK. That silly plastic grommet thing rots away and disintegrates over a couple of decades of heat cycles.
